WTH is the ZHA network map looking so messy and is not usable?
WTH is the ZHA network map looking so messy when you need to find the weakest link in your Zigbee network or need to debug? With your mobile app you cannot use it at all and requires a very large flatscreen. Using this ZHA map feels like being a fly trapped in a spiderweb untangling itself. Why does it have to look so chaotic when it’s supposed to provide clarity? I mean… following the lines to discover what device is connected to a router device or could be in trouble in your network is too complicated now.
It would be great when a smart developer create:
  1. a proper map or table that makes sense. Something clean and functional, like a simple list for each device showing its connected devices, complete with signal strength indicators, last seen and more.
  2. See below some other great ideas:
Home Assistant is such a powerful platform, yet this critical (debug/troubleshoot) feature could be improved. It would be great to develop new helpful functionalities and add it as an enhancement to the ZHA network map option. Let’s develop this tool so we can more rely on!
Will this get your vote?
See the example.
All the competitors to HA, all open source zigbee/zwave packages, even the store bought compentitors have routing maps like this. So phrases like " It’s not rocket science—it’s just well spend design." are pretty misleading when all the top dogs do this.
I suggest you provide a hand drawn diagram showing what you’d expect to see.
The number of device-to-device links is fundamental to mesh networking.
Mesh network devices know network conditions better than a sysop, so are designed to operate autonomously. A diagram can only really show where a device has poor coverage to peers, and where an other mains-powered router could help reinforce the mesh. In fact, the mesh map may not be telling you what you believe it does.
Other networks can be visualised by techniques like a heat map, but as mesh works link-by-link, that isn’t a useful view.
Signal strength / quality could be shown by thicker lines or colour coding as an option. That might help spot interference and poor mesh.
I’ve seen other platforms offer dynamic positioning of nodes as you zoom in, but that doesn’t change the need to show individual links.
This is not rocket science, this is rocket engineering! :slight_smile:
(the science is very simple - the engineering is anything but)
Totaly.
it seems that Z2M have a better network map
@petro Thank you for your reply. When I referred to “well-spent design,” I was pointing to the overall UI/UX philosophy rather than suggesting this particular feature is groundbreaking.
It’s clear, though, that this is an expected feature even among top platforms, and the omission is something Home Assistant could and maybe should prioritize.
Here’s a quick diagram/table I drafted on your request illustrating what a typical routing map might look like for clarity. But remember, this is just an example I created for you:
And I’m sure more users will come up with requirements that could complete this WTH suggestion. More questions feel free to ask. Thank you.
That looks very similar to zha-network-card.
Thank you for your reply. Looks almost similar but seems to miss:
  • the information of what device is connected other devices.
  • Also missing the simplified signal clarification such as Weak/Normal/Strong.
Is my assumption right?
But a table with one entry per device is just not how mesh networks operate. Zigbee and Z-Wave are not like Wi-Fi, with hub-and-spoke network paths, giving a single measure of LQI / RSSI.
Mesh networks are dynamic, with nodes choosing which of the routing peers they can see should carry a message on an instantaneous basis. You don’t get to choose, only monitor where the mesh may be weak.
The large number of lines on the spider diagram is showing the peers each node can see. Each node could be monitoring many peers - each with a different, changing LQI.
Why am I telling you this? Because so many folk are used to Wi-Fi networks, and try to use similar engineering and sysadmin with mesh. Mesh is different.
@FloatingBoater Isn’t that what the last column in my example/draft table shows?
It shows 1 (zigbee) device with one or multiple pears/connected devices? And yes indeed, the device cannot be connected with itself. This is my mistake in the quickly drafted example. So for example (not shown in the table) Device 1 is connected to device 3 en 4. Of maybe in a Mesh network even more devices.
Or do you mean something different? Please clarify. Thank you.
No. Device 1 was connected to device 3 and device 4. It probably isn’t any more.
As @FloatingBoater says, these maps (and your table) may be useful if you’re trying to decide where to add another router. Apart from that, I’m not sure why you would want one.
I mean each mode is dynamically tracking the LQI of every other node it can see (within config limits; only when awake), and choosing which mains powered router to pass a message to. Some of my devices show 12x neighbours.
A table is fundamentally a 1:1 representation. Mesh is fundamentally 1:Many.
That’s why the ZHA network map is so messy - each node shows all other nodes it can see.
Even more complex… for each path between two nodes (A and B) should you show the signal from the perspective of node A or node B? They are different.
I assume ZHA picks one for colour coding and shows two numbers on a link (for mains powered router nodes, not battery as they sleep so probably don’t report as much data), with higher being better (e.g. >192 is green).
I’ve not actually pulled data from the ZHA API to know what is actually reported, but am just trying to show the complexity of representing mesh networks. IMHO, a table isn’t going to cut-it, except if you select ONE node to measure from.
To throw some constructive ideas out there:
  • ZHA already uses colour codes and shows bi-directional LQI as annotations like 200/185), however a “Show Issues Mode” might help by switching from the existing “emphasise good” to “emphasise bad” to make poor mesh LQI stand out more and putting working nodes into the background.
    When was a dead node last seen? What was the battery level?
  • The existing ZHA diagram might also place nodes better, and have better zoom controls.
    This could be as simple as configuring a standard library better - but like most engineering, the fact it doesn’t already, suggests much more work.
Generally, I’ve only used a mesh diagram to get a rough idea where there is a “thin patch” with nodes with fewer “neighbours”. The hard part of interpretation is the nodes show radio proximity - not physical and capturing the latter in 3D is orders of magnitude harder.
The graph sucks. That’s the bottom line. The text is hard to read. Lines are hairthin. The physics are wonky. The mesh is so big, it is in effect unusable for anyone with more than a few devices. And I can’t control-click on a device to see the device page.
Please fix.
I still don’t understand what you’re going to use it for:laughing:
To trace a path between malfunctioning devices and debug ZB issues.
But… the path will have changed. They change all the time. :confounded:
Not for the troublesome devices i can tell ya! :joy:
I think the simplest improvement would be to use colour to differentiate Coordinator, Routers, and End-Devices!
That’s a nice and easy-to-implement suggestion!
I didn’t vote because I don’t want a list. The graph makes the most sense from a technical standpoint, and it works quite well for showing the mesh. That doesn’t mean the graph could use some improvements, however you aren’t asking for that.
