This is a massive miss as I can’t sort or filter on node status to see my offline devices/how to fix via reinterview.
Offline / dead devices should also show up under fix me…
Please vote for your own WTH
meanwhile use this markdown
- type: markdown
content: >
{%- set ns = namespace(nodes=[]) %}
{%- for dev_id in integration_entities('zwave_js')|map('device_id')|unique %}
{%- set node_id = (device_attr(dev_id,'identifiers')|first|last).split('-')[1] %}
{%- set ns.nodes = ns.nodes + [(node_id|int,dev_id)] %}
{%- endfor %}
ID | Manufacturer | Product | Product code | Name by user | Location / Area | FW | Status
{%- for node_id,dev_id in ns.nodes|sort(attribute='0') %}
{{ ['[**%01d**](/config/devices/device/%s)'|format(node_id,dev_id),
device_attr(dev_id,'manufacturer'),
device_attr(dev_id,'name'),
device_attr(dev_id,'model'),
device_attr(dev_id,'name_by_user') or '',
area_name(dev_id) or '',
device_attr(dev_id,'sw_version'),
device_entities(dev_id)|select('search','_status')|map('states')|list|join('|') or '' ]|join('|') }}
{%- endfor %}
Ive just added the node_status column (seems hacky but ok) so you can check and have direct entry to the device
(credits go to Freshcoast)
believe there is a FR for this too somewhere
