Wunda UFH Smart Connection Box
I’ve just taken delivery of Wunda underfloor heating package which includes the Smart HubSwitch and Smart Connection Box (effectively the wiring/relay box for actuator/pump etc control). The HubSwitch sits between WiFi and the Connection Box. I’ve seen other threads on here regarding using HA as the control by replacing the Wunda user app. What puts me off is that it appears to still be reliant on a Cloud to operate.
So, has anyone interfaced HA to the Smart Connection Box, bypassing the Cloud and HubSwitch?
As this kit arrived nearly 24 hours ago, obviously I’ve looked inside the device and the Smart Connection Box runs an STM32WLE5 which supports LoRa, (G)FSK, (G)MSK and BPSK. I doubt it’s running LoRa as there is no written EUI which maybe required and I’ve not used the other protocols.
Hello jonr6846
If your search did not find a match, 2 things.
It’s a weird name, so try to connect with the Tuya Smart Life app, if it connects, you can use one of the Tuya Integrations.
If searching and Tuya doesn’t work, this URL is where you request new integrations from the community: home-assistant · Discussions · GitHub
Thank you Sir!
I loaded the Tuya Smart Life app and put it in pairing mode along with the Wunda Smart Connection Box - but alas the app didn’t recognise/air with it.
I’ll follow the new Integrations URL - Thanks for your help
