Wunderground not updating
The Wunderground intergration is not auto-updating. If I reload the integration I get the last values. In the LOG there’s an error. Someone have a idea what the problem is?
Deze fout is ontstaan door een aangepaste integratie.
Logger: homeassistant
Bron: custom_components/wundergroundpws/weather.py:138
integratie: Wundergroundpws (documentatie, problemen)
Eerst voorgekomen: 11:46:39 (48 gebeurtenissen)
Laatst gelogd: 15:47:23
Error doing job: Task exception was never retrieved
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 1504, in _async_process_registry_update_or_remove
self.async_write_ha_state()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 998, in async_write_ha_state
self._async_write_ha_state()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 1119, in _async_write_ha_state
state, attr, capabilities, shadowed_attr = self.__async_calculate_state()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 1058, in __async_calculate_state
attr.update(self.state_attributes or {})
File “/usr/src/homeassistant/homeassistant/components/weather/init.py”, line 691, in state_attributes
if (visibility := self.native_visibility) is not None:
File “/config/custom_components/wundergroundpws/weather.py”, line 138, in native_visibility
return self._attr_visibility
AttributeError: ‘WUWeather’ object has no attribute ‘_attr_visibility’. Did you mean: ‘native_visibility’?
That might be an actual issue, in which case you should write up an issue for it n core, or at least see of someone else has done so and in that case thumbs-up the existing issue…
Reporting issues - Home Assistant.
Issues · home-assistant/core · GitHub.
It is a custom integration, should be reported in the custom integrations github.
