I can see the various entities of the WVC-1200 Micro Inverter within the Tuya IoT website, such as total power and inverter temp, but in the Tuya integration that I have got setup in Home Assistant I can see the device, but it has no entities.
Is there some sort of configuration I need to do in Tuya IoT to get these to come though?
Hello
same thing for me. My micro-inverter is seeing with only a switch entry (On/Off). By default voltage, power & tension are disabled.
If i enable them, no error but stay at null value…
Whereas with Tuya app, everything is working correctly.
Regards
I’ve the same issue.
My device is well add in Tuya integration. The three entities (Courant, Puissance et Tension) was disable by default. After enable it, the value stay at 0.
I also saw that although values are null, it’s seem to have connection with the device when sun rise.
