I have installed home assistant, but i missing the www folder in the config directory.
How can i fix this, when i make a folder www the configuration can not find this folder.
Manually add it. Then restart home assistant.
yes i have this already done and put some files in the folder. But my configuration file don’t find the folder
Did you restart home assistant though? Home Assistant won’t see it until it’s been restarted after you made the folder.
To access files in the folder on the config side you have to use /config/www/
But to access them in a browser - eg images etc, you need to use /local/
Problem is fixed, i have shutdown the complete vm of home assistant.
Now i can play my camera because some files i need them.
Thanks for your help and ideas
You only had to restart the home assistant server.
