kbromer
(KB)
1
Upgraded to 2024.2.1 this evening. Everything was working well before, and everything functions normally after the update as well.
However, I’m receiving non-stop disconnect errors (every 90s) in my HA logs from Wyoming:
Satellite has been disconnected. Reconnecting in 10 seconds…
Its a bit reminiscent of the homassistant-satellite issue - its throwing errors constantly but seems otherwise unaffected.
Any suggestions? Did I miss something I needed to do to update my satellites? Is there some way to suppress or address the underlying error?
python
2
I have upgraded wyoming-sattelite and errors gone.
I have this same error. How did you upgrade wyoming-sattelite? I believe I’m up to date on everything and I can’t get this warning to go away.
kbromer
(KB)
4
Stop service
sudo systemctl disable --now wyoming-satellite.service
Pull latest changes
cd /wyoming-satellite
git pull
Run install script
script/setup
Reenable service
sudo systemctl enable --now wyoming-satellite.service
A bit late getting back to this as I just ignored the problemand hope, like so many times, the problem would magically fix itself
Thank you for the reply. I’ll give it a try.
