Wyze cameras and HA?
Will Wyze cameras/devices work with Home Assistant? I’m pretty sure they don’t support it but maybe there’s a workaround?
Yes, likely with mixed results. I suggest you do a bit of research.
Here is some advice on how to search here for an answer.
It is possible, as I’ve done it. You have to setup the camera to use RSTP in the Wyze app settings. It only works for relatively new cameras and not the very early generations. You can search with Google Gemini for solutions.
Check out this HA app repo. It allows you to stream Wyze cams locally.
AlexxIT/go2rtc: Ultimate camera streaming application
