Wyze Cams using wz_mini_hacks, go2rtc RTSP, motion detection, and two-way audio. Sorta
I’m running Home Assistant in Docker for a little over a year at this point. I got sick of writing little isolated scripts trying to connect different smart devices and would have started sooner if I realized how much HA can glue it all together.
I’ve been using Wyze Cams for a few years now. I started with some V2 cams using one of the earlier RTSP beta firmware versions. At some point I added a few more V3 cams. I’m up to about a half-dozen of each and one Pan V1.
RTSP was always clunky, but worked fine in iSpy where I used it primarily. When I added the cameras to Home Assistant it bothered me that the audio channel didn’t work right, but it wasn’t a show-stopper. I could always just pop open the Wyze app on my phone if I really needed audio.
Over the past couple months I’ve been playing with wz_mini_hacks and found that by switching to go2rtc audio worked. It also loaded the camera feeds faster since wz_mini_hacks provides a snapshot URL. I played with the cmd waitMotion to do area detection within Home Assistant, initially via API, and now via an Automation Webhook. Everything says two-way audio doesn’t work with the Wyze cams out of the box.
I noticed though that I could do cmd aplay, isn’t that sort-of two-way audio? I played with converting files to proper low quality .wav format and could trigger those via script. Then played with the file pipe (mkfifo) method listed in the wiki.
I figured out I could use the gstreamer configuration to configure a media_player in Home Assistant that writes out to a fifo. Now I have HA writing to a fifo in Docker:
media_player:
  - platform: gstreamer
    pipeline: "audioresample ! audioconvert ! audio/x-raw,rate=8000,channels=1,format=S16LE ! wavenc ! filesink location=/media/voice/snapcast_gstreamer"
and cmd aplay listening to a fifo on the cam
cmd aplay /opt/wz_mini/tmp/stream 50 2> /dev/null &
I’m looking for a better way to connect the two together. Ideally with something like snapcast, which I’m just dipping my toe into now, so I could potentially pick which cameras are listening to which streams, perhaps have multiple streams going around the house at the same time.
So far this works, sorta. I can start a listener in the Docker container, probably outside of it as well, and can probably mount the same directory I could use in snapcast for the pipe into HA Docker as well, but this is what I’m doing:
while true; do cat /config/voice/snapcast_gstreamer; done | nc -l -p 4001
Then on the Wyze cam I can connect to that listener and output the stream to the pipe that cmd aplay is listening to.
nc 192.168.42.1 4001 >> /opt/wz_mini/tmp/stream &
And if I time it all right, I can play a media file in Home Assistant and it will come out of the speaker of the Wyze Cam. That’s two-way audio, right? The problem is, and I haven’t figured out all the exact timing, that I have to start it all in the right order and then it only plays once. I think this has to do with nc liking to exit when it gets an EOF. I think I got the server/listener side working, but both the Wyze nc “client” and the cmd aplay command exist after the stream ends.
I’m sure I could loop the client side too, maybe digging into snapcast is the right path, and I can just have it send silence which will keep the stream going and keep it all active and I’m over thinking it. Either way I need to write up some daemons or command_line integrations to start these processes and keep them running on HA and each of the cameras.
Instead of continuing to build the Rube Goldberg contraption I’ve started I ask you is there a better, more direct way to get audio out of Home Assistant? I think I want it to show up as a media_player, but could be convinced I’m doing it wrong. I’d love to eventually have a PTT (push-to-talk) button on my glance camera cards that could just record a bit of audio and stream it to the speaker. If I have to go into Media → Text-to-speech and type it out, that’s fine too.
Thoughts?
Mind telling me how to get gstreamer integrated to docker? The instruction is not very clear on how to do it. After adding it to configure.yaml, it says that we need to install some python dependency packages. Where should we install these dependencies from? From the host machine or from the HA docker container (via its shell)? I see there is a gstreamer docker available. Will this gstreamer docker be a little easier to use/integrate? Thanks.
Edit:
Figured out that I need to install from inside of the docker.
Sorry, I stopped checking back on this thread after a few months of no replies. Sounds like you figured it out, but for those who haven’t: these are the notes I have from when I was running HA in Docker.
apk add gstreamer gst-plugins-good gst-plugins-bad gst-plugins-ugly gobject-introspection-dev pkgconfig build-base
pip install pgi PyGobject
You have to run the above every time you download a new image in Docker. I never got comfortable enough running my own Dockerfile to make my own image with them integrated. I’ve since moved on to running HAOS in ProxMox on a TFF (Tiny Form Factor?) server. I’ve also put the two-way audio experiment on the back-burner. I’d love it if someone had thoughts though.
