@Noblewolf Need your help. I just followed these instructions: GitHub - romedtino/simple-wyze-vac: Home Assistant Custom Component for Wyze Vacuum , but when I go to enter username and password, then the TOTP, could not log in. I followed the instructions to remove 2FA from the wyze app. Then setup 2FA in wyze app, copied the secret code…went back to the HA Simple Wyze, and put in the user name, password, TOTP code…still would not allow me to sign in.
So - I tried something. I removed 2FA in Wyze and was able to add in Simple Wyze Vac with no problem. I then set a simple automation to clean the guest bedroom.
So I went back and setup 2FA and repeated trying to setup the Simple Wyze Vac function…but got the same results: but when I go to the enter username and password, then the TOTP, could not log in. I followed the instructions to remove 2FA from the wyze app. Then setup 2FA in wyze app, copied the secret code…went back to the HA Simple Wyze, and put in the user name, password, TOTP code…still would not allow me to sign in.
Well - I have determined the 2FA is preventing me from using the Simple Wyze Vac.
If I disable the 2FA its works. If I enable it - it does not work - meaning I can not log / set up Simple Wyze Vac. I am copying the data, so there is no data entry error.
Suggestions?
Thoughts?
