Wyze Vacuum Automation Help
Home Assistant Setup
After installing, restarting, and creating the below routine, the automation doesn’t run (and without any errors in the homeassistant.log file.
- id: vacuumTimeBased1
  alias: "Run vacuum at certain time"
    - at: "10:36:00"
      platform: time
    - service: vacuum.send_command
        command: sweep_auto
        entity_id: vacuum.vacuum
Not really sure where I went wrong, its a pretty simple test to see if the vacuum will be kicked off at a specific time.
Any thoughts?
Any ideas?
