X-10 on/off toggle wont stay on
Fresh install on Rasp Lit on RPI 3B+
as per the Python VE install
Added three x10 devices controlled by a CM11 on /dev/ttyUSB0 to configuration.yaml as per the documentation on here
light:
  • platform: x10
    devices:
    • id: b1
    • id: b2
      devices:
    • id: b3
I can turn the devices on, but not off.
They turn on, wait a second and the toggle flicks back to off, but the device stays on.
Cannot then turn the device off.
From a few threads I have found about other devices, I think this could be a device state/status issue but cant see what to do about it , and as X10 units do not report device status, guessing some ‘fudge’ to get around this ?
In a separate Terminal type heyu engine while HA is running. You need to setup a systemd service to run heyu on boot.
OK, got it sorted.
got the Heyu Engine starting from systemd as a service now and all is good
