X-Sense Security - is it possible to create an integration?
You probably have stand-alone wifi-devices? I did not have those when I started on the library. @jarnsen has provided me access to one, so I can add it soon. Maybe next week, but I’m also working on other things.
The camera is a separate thing, the x-sense api retrieves some access keys and then a different API is used. It will probably take longer to implement that, but it should be possible. I think that a separate library for the camera would make sense. Maybe such a library already exists.
Thanks for all your work on this. I have three of the stand alone smoke detectors which sound like are not working yet. However, this is the message I get from the integration if that helps.
Image 4-30-24 at 9.27 AM
the coroutine message is a bug that I did not know about, will fix that as well
What would help me if I know all the devices that are stand-alone and not working.
I have tested with this one:
  • XS01-WX
i add in the discription that only supportet devices are allowed to share. @theosnel you are also access to the repo, i invited you.
there is the repo
but it´s in german, if any person is able to create english subs?
yes, but I’m curious about which devices are currently in use that are not supported. In other words: for which devices is support needed that we do not support yet.
Thanks Theo for your quick reply, in fact i have both the smoke detectors (XS01-M) via the base station (SBS50) and standalone (S01-WX), furthemore i have the CO-detector (XC01-R). I receive the same error message as @komtx . The “coroutine message bug”.
I also did understand the cam integration (i use the SSC0A) is another story :wink: Thanks for all your efforts !
Best, Steffen
we need help
this are the confirmed devices
  • base station (SBS50)
  • heat alarm (XH02-M)
  • carbon monoxide alarm (XC01-M)
  • smoke detector (XS01-M)
  • waterleak detector (SWS51)
  • hygrometer-thermometer (STH51)
1.: who has another device running with the integration
2.: who has another device that doesn‘t work with the integration and needs support fort it
3.: best way for testing is to share the device via the X-Sense app
Sorry about that! I have the SC07-WX units. Happy to share a unit if you give me the best address
Thanks!!
Thats the Single wifi Carbon Monoxide sensor, i think the same Connection as the fire XS01-WX Fire Sensor
It’s carbon plus smoke if that makes any difference. It is wifi.
Can someone test how large the range between base station and Sensor Can be. Lora is supposed to be extremely far.
Hello everyone, first of all thank you for this great integration. I just installed it with my base station and fire alarm.
What I notice is that no correct im
age is displayed. But it’s just a “small thing”
In my case, the base station is located fairly centrally in the kitchen, but I can reach all smoke detectors in the 120 m² house, including those in the garage, with full reception
is it possible to go for a walk with one smoke detector and push the test button to check the range
I did it and I reach the property line, so my WiFi is also off. That’s approx. 20 meters in all directions from the base station
ok, thats not sooo far. thanks
I’ve got the XS01-WX working now, the code needs some cleanups, but I will push it soon. Hopefully it will also support the other stand-alone devices, but wasn’t able to test that yet.
Also moved the serial-number to device info. I think it belongs there, because it will never change.
Just updated the xsense-lib and the component. It should now support the stand alone smoke detector XS01-WX. If we are lucky, the SC07-WX works as well, but I have not been able to test it yet.
If fields have a slightly other name (the API is not very consistent), some data will be missing from the untested devices.
@Jarnsen is now working on the HACS version.
@all HACS is online Version 1.0.7, please Test all Devices and Report here wich device work.
