This MCCGQ11LM device is mounted on a window
When the window opens, the device goes from closed to very briefly open to very briefly closed to open. It does the same thing when the window is closed
I have another sensor set up on the window next to this one and it works fine
This is the Zigbee device Signature. It is exactly the same for both devices.
"node_descriptor": "NodeDescriptor(byte1=2, byte2=64, mac_capability_flags=128, manufacturer_code=4151, maximum_buffer_size=127, maximum_incoming_transfer_size=100, server_mask=0, maximum_outgoing_transfer_size=100, descriptor_capability_field=0)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x5f01",
"in_clusters": [
"0x0000",
"0x0001",
"0x0003",
"0xffff"
"out_clusters": [
"0x0000",
"0x0004",
"0x0006",
"0xffff"
"manufacturer": "LUMI",
"model": "lumi.sensor_magnet.aq2",
"class": "zhaquirks.xiaomi.aqara.magnet_aq2.MagnetAQ2"
