Kbrown01 I now know the difference between Allin One and Split Up. I will be using Split Up in the future. I will retry inserting the code in YAML. How can I verify the Xantech HACS is installed correct and enabled
Thank You for replying. No, I do not believe it showed in Integrations; it showed under HACS. I wiped my latest HA due to frustration. I am building two new HA boxes, one for production and one for testing. I hope to have both done this week. How do I get Xantech from under HACS to integration?
This is where it is broken. When I try to add the integration, I get âthis integration cannot be added from the UI.â Thank you for all your help. It is great having support for newbies!
I was able to get Xantech into Integrations; now I am figuring out the card or frontend
I would assume then you have it working.
Did you test with a simple media player and like WifI as source and play Sportify to the DAX?
No, I do not have it working. I figured I needed some kind of dashboard item to test. How do I test it as is? I have YAML in, and the integration for Xentech is showing under integrations. Thank you again!
In order to give good answers using your setup, please post your YAML for the DAX. If setup somewhat, you should have a media_player for each zone using the name in the YAML. You can use the entities and filter by Xantech integration as shown below:
Note: The âHouse Audioâ one is the default to the DAX, the rest are each individual zone.
In my case, from this:
- platform: xantech
type: dax88
port: /dev/ttyUSB0
zones:
11:
12:
13:
14:
15:
16:
17:
18:
sources:
1:
2:
3:
4:
5:
6:
7:
8:
It works so COOL! Now I need to get it to a dashboard, preferably with the Wifi or Sonos Port attached, to be able to pick music from the same spot. I will also try and add HA 3mm audio connection to the DAX88 input as well so HA would be able to choose music.
You only need HA input if it isnât Wifi.
Like you can use HA to control Spotify and select the unit as the âplayerâ
This is SpotifyPlus playing to the âRio Crest Zonesâ (my DAX unit) ⌠no wires.
And you implement picking what you want to play per zone, like this:
That is perfect. I did mange to install Spotify on my HA so I have that installed and kind of working shows music but canât connect it to my local 3.5 mm speaker out. So how do I get this to the next level.
You do not need to connect it.
First check in the spotify app and see if your DAX unit shows up.
Then you control with Spotify app and it wireless streams to your DAX on the WiFi input. See below, Spotify is playing to my DAX (Rio Crest Zones). And it would on WiFi as the input.
I remember seeing DAX on Spotify but couldnât make it work. I didnât try setting DAX to WiFi, but I will try that. I will have to use the DAX app to adjust input I still donât have any dashboard way to change inputs per zone yet.
I tested my DAX with Spotify on HA, and it works great. However, I had to set the Zone and Input to WiFi from the DAX app. How do I get this to a dashboard?
Thank you again Kbrown01 for getting me this far. Can you help me get the DAX and Spotify together on a dashboard like you showed?
The whole thing is massive. I will try to gather and post on github
Thank you, let me know if I can donate to your work.
So sorry for the noob question. Totally new to Home Assistant. Canât find step by step instructions for making this integration work. I have installed HACS and downloaded rsnodgrass/hass-xantech from GitHub. It does not show up under integrations. I did see above âmedia_player.yamlâ but donât know where to place that line. I have a Dayton DAX 88 and would love to get this working. Thanks for your efforts on this integration!
If you are new to HA, first question is do you use a single configuration.yaml
or one that uses includes?
In my case, I have broken my configuration.yaml
into files and use includes.
so configuration.yaml
has:
media_player: !include media_player.yaml
And them (of course this is for my unit), the included media_player.yaml
has:
- platform: xantech
type: dax88
port: /dev/ttyUSB0
zones:
11:
12:
13:
14:
15:
16:
17:
18:
sources:
1:
2:
3:
4:
5:
6:
7:
8:
This also means my DAX88 is connected via the Serial to USB cable and in is ttyUSB0
. media_player.yaml
is in the same directory as configuration.yaml
