I can’t find a way to get the xbox integration working.
Things I’ve tried (from searching google, forum and Openai):
- Remove xbox integration again, restart home assistant and add it again using private browser
- Remove Oauth from microsoft allowed applications, and do the step 1 again.
I can control the xbox with the Xbox app. No problems there.
Error in HA:
Error setting up entry Home Assistant Cloud for xbox
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 980, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs) # type: ignore[return-value] # noqa
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1112, in create_connection
transport, protocol = await self._create_connection_transport(
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1145, in _create_connection_transport
await waiter
File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 964, in _read_ready__get_buffer
nbytes = self._sock.recv_into(buf)
ConnectionResetError: [Errno 104] Connection reset by peer
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 388, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/xbox/__init__.py", line 60, in async_setup_entry
consoles: SmartglassConsoleList = await client.smartglass.get_console_list()
File "/usr/local/lib/python3.11/site-packages/xbox/webapi/api/provider/smartglass/__init__.py", line 54, in get_console_list
resp = await self._fetch_list("devices", params, **kwargs)
File "/usr/local/lib/python3.11/site-packages/xbox/webapi/api/provider/smartglass/__init__.py", line 359, in _fetch_list
resp = await self.client.session.get(
File "/usr/local/lib/python3.11/site-packages/xbox/webapi/api/client.py", line 86, in get
return await self.request(hdrs.METH_GET, url, **kwargs)
File "/usr/local/lib/python3.11/site-packages/xbox/webapi/api/client.py", line 60, in request
await self._auth_mgr.refresh_tokens()
File "/usr/src/homeassistant/homeassistant/components/xbox/api.py", line 31, in refresh_tokens
await super().refresh_tokens()
File "/usr/local/lib/python3.11/site-packages/xbox/webapi/authentication/manager.py", line 73, in refresh_tokens
self.user_token = await self.request_user_token()
File "/usr/local/lib/python3.11/site-packages/xbox/webapi/authentication/manager.py", line 138, in request_user_token
resp = await self.session.post(url, json=data, headers=headers)
File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 536, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 540, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 901, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 1209, in _create_direct_connection
raise last_exc
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 1178, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 988, in _wrap_create_connection
raise client_error(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host user.auth.xboxlive.com:443 ssl:default [Connection reset by peer]
