Xbox integration keeps failing. Logs show a 500 error from Nabu Casa
My Xbox integration in HA keeps failing. This is the error in the logs. What might I do to fix it?
Logger: homeassistant.config_entries
Source: components/cloud/account_link.py:116
First occurred: July 11, 2022 at 10:51:43 AM (1 occurrences)
Last logged: July 11, 2022 at 10:51:43 AM
Error setting up entry Home Assistant Cloud for xbox
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 353, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/xbox/__init__.py", line 101, in async_setup_entry
    consoles: SmartglassConsoleList = await client.smartglass.get_console_list()
  File "/usr/local/lib/python3.10/site-packages/xbox/webapi/api/provider/smartglass/__init__.py", line 54, in get_console_list
    resp = await self._fetch_list("devices", params, **kwargs)
  File "/usr/local/lib/python3.10/site-packages/xbox/webapi/api/provider/smartglass/__init__.py", line 359, in _fetch_list
    resp = await self.client.session.get(
  File "/usr/local/lib/python3.10/site-packages/xbox/webapi/api/client.py", line 86, in get
    return await self.request(hdrs.METH_GET, url, **kwargs)
  File "/usr/local/lib/python3.10/site-packages/xbox/webapi/api/client.py", line 60, in request
    await self._auth_mgr.refresh_tokens()
  File "/usr/src/homeassistant/homeassistant/components/xbox/api.py", line 27, in refresh_tokens
    await self._oauth_session.async_ensure_token_valid()
  File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 475, in async_ensure_token_valid
    new_token = await self.implementation.async_refresh_token(self.token)
  File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 89, in async_refresh_token
    new_token = await self._async_refresh_token(token)
  File "/usr/src/homeassistant/homeassistant/components/cloud/account_link.py", line 116, in _async_refresh_token
    new_token = await account_link.async_fetch_access_token(
  File "/usr/local/lib/python3.10/site-packages/hass_nabucasa/account_link.py", line 112, in async_fetch_access_token
    resp.raise_for_status()
  File "/usr/local/lib/python3.10/site-packages/aiohttp/client_reqrep.py", line 1004, in raise_for_status
    raise ClientResponseError(
aiohttp.client_exceptions.ClientResponseError: 500, message='Internal Server Error', url=URL('https://account-link.nabucasa.com/refresh_token/xbox')
Anyone got any ideas?
Did you ever find an answer to this? I recently started seeing the same issue.
No. I’ve given up on the Xbox platform. :frowning:
