I have an automation setup that switches my AVR to the xbox as soon as the xbox goes online. Since the addon was made into an integration, my AVR keeps seemingly randomly switching to my Xbox although it has not turned on. Checking the logs, I can see that my media_player.xboxone “turns on” (without actually turning on) for a couple of seconds every couple of hours.
Is this behaviour expected? And if yes, why?
Mine stays off, but I have my xbox turn OFF not on STANDBY.
Perhaps you can find the duration then set the AVR automation to trigger when Xbox is on for that plus 2 seconds or something?
Edit, its more than likely the xbox checking in with servers for updates/etc. On standby I experience this with my Tizen TV. (1 second every 30 minutes on the dot)
My Xbox powers off, no standby. That workaround you suggested is a good idea, but logs show Xbox turned on for over a minute sometimes. I might try readding my Xbox if this is only an issue concerning my device.
Did it go “on” or “unavailable”? Mine was offline a bit last night for a minute or two. My automation is when the Xbox is state: on, guessing yours is the same.
Did reinstalling the integration solve the issue? I got the same problems on my xbox series x. It goes to on a lot (in the integration). It make all kind off mystical issues in my TV room due to the automations I have made…
The xbox is however seemingly off. But I also expect it to go online to check for updates. As far as I understand it will do this while also while being off, not only on standby.
It seemed like it did help at first, but the behavior returned.
What I did as a workaround for now is also include the sensor for my Xbox id in my automation. This works as long as there is no update prompt at the beginning of starting the console.
There’s an option to put the xbox in a standard, non-energy saving sleep mode for some scheduled hours. Your best bet would be to disable energy saving for whatever hours you’re most likely to want the ability to remotely power it on.
I just realized that I only see this option on my spare Xbox One that’s enrolled in the insider program. The ‘Active Hours’ scheduling feature must not be rolled out beyond the insider previews yet. My mistake!
Hello together,
I struggle with the unperformant/unreliable switching on and off the XBox. E.g., wenn I try to switch on, it switches in and goes immediately off, I have no idea.
I try to overcome this with a own defined media player but it is not working.
Many thanks in advance for any help!!
What I have…
The XBox integration
Via UPnP sensing the on/off status of the XBox as via the integration it takes too much time for updating
What I try…
Create a new media player that takes the status from the UPnP sensor and use the XBox integration to send the on/off command
