Xbox One Ir codes for Broadlink RM
Hi there,
i’ve been trying to find IR codes for power on and off for my Xbox one for the last few days and had no luck. I found a bunch of codes here: but once converted to base64, they don’t seem to work for me. anyone had luck setting up xbox one with IR codes?
could´t use as well, nd also trying to find a way o turn on my xbox
I’m also looking for the IR codes for Xbox One, and haven’t been able to make any I’ve found on the web work yet.
I was able to use this to turn on:
But it can’t be used to turn it off, which I still need.
Got it!
The codes are:
command_on: 'JgBQAAABKJQTEhMTExITEhQSExIUEhM3ExMTEhMSFDcTNxQSEzcTOBMSEzcUEhM3FBITNxMTExITNxQSEzcUEhM3ExMTNxM3FAAFngABKUoTAA0FAAAAAAAAAAA='
command_off: 'JgBQAAABKJQTEhQSExIUEhMSFBITEhM3FBITEhQSEzcUNxMSEzgTNxM3FBITEhQ3ExITOBMSExIUEhM3FDcTEhM3FBITNxQ3EwAFnwABKUkTAA0FAAAAAAAAAAA='
I got these by using the Sure remote app on my phone (which has an IR blaster), and using that to learn the codes.
All XBox One IR Codes for Broadlink:
   xbox_power:
     friendly_name: "XBOX POWER"
   xbox_home:
     friendly_name: "XBOX HOME"
     command_on: 'JgBQAAABKpIVDxURFRAVDxURFRAUEBU2FBAVERQRFDUVNRURFDUVNhQRFBEUNRURFBEVNRQ1FREUNhQ2FRAUNhU1FBEVEBQ2FQAFbwABK0cVAA0FAAAAAAAAAAA='
     command_off: 'JgBQAAABKpIVDxURFRAVDxURFRAUEBU2FBAVERQRFDUVNRURFDUVNhQRFBEUNRURFBEVNRQ1FREUNhQ2FRAUNhU1FBEVEBQ2FQAFbwABK0cVAA0FAAAAAAAAAAA='
   xbox_ok:
     friendly_name: "XBOX OK"
     command_on: 'JgBQAAABKJQUERMSExITEhMSExIUERM3FBETEhMSFDYSOBMSEjgTNxMSEzcUERMSEhMUNhITFBETNxMSEzcUNhM3ExMSNxM3FAAFcQABJ0oUAA0FAAAAAAAAAAA='
     command_off: 'JgBQAAABKJQUERMSExITEhMSExIUERM3FBETEhMSFDYSOBMSEjgTNxMSEzcUERMSEhMUNhITFBETNxMSEzcUNhM3ExMSNxM3FAAFcQABJ0oUAA0FAAAAAAAAAAA='
   xbox_up:
     friendly_name: "XBOX UP"
     command_on: 'JgBQAAABKpIVEBUQFRAVEBUQFRAVEBU1FRAVEBUQFTUVNRUQFTUVNRUQFTUVNRU1FTUVEBUQFRAVNRUQFRAVEBUQFTUVNRU1FQAFbwABK0cVAA0FAAAAAAAAAAA='
     command_off: 'JgBQAAABKpIVEBUQFRAVEBUQFRAVEBU1FRAVEBUQFTUVNRUQFTUVNRUQFTUVNRU1FTUVEBUQFRAVNRUQFRAVEBUQFTUVNRU1FQAFbwABK0cVAA0FAAAAAAAAAAA='
   xbox_down:
     friendly_name: "XBOX DOWN"
     command_on: 'JgBQAAABKpIVEBQRFBEVEBQRFBEVEBQ2FRAUERUQFTUUNhQRFTYTNhU1FTUUNhU1FTUUERUQFRETERUQFRETERUQFTUVNRU1FQAFcAABKkgVAA0FAAAAAAAAAAA='
     command_off: 'JgBQAAABKpIVEBQRFBEVEBQRFBEVEBQ2FRAUERUQFTUUNhQRFTYTNhU1FTUUNhU1FTUUERUQFRETERUQFRETERUQFTUVNRU1FQAFcAABKkgVAA0FAAAAAAAAAAA='
   xbox_left:
     friendly_name: "XBOX LEFT"
     command_on: 'JgBQAAABK5IUEBUQFREUEBUQFREUEBU2FBAVEBURFDUVNRUQFTUVNhQQFRAVERQQFRAVNRUQFREUNRU1FTYUNRU1FRAVNRU2FAAFbwABK0cVAA0FAAAAAAAAAAA='
     command_off: 'JgBQAAABK5IUEBUQFREUEBUQFREUEBU2FBAVEBURFDUVNRUQFTUVNhQQFRAVERQQFRAVNRUQFREUNRU1FTYUNRU1FRAVNRU2FAAFbwABK0cVAA0FAAAAAAAAAAA='
   xbox_right:
     friendly_name: "XBOX RIGHT"
     command_on: 'JgBQAAABKpIVEBUQFBEVEBUQFBEVEBU1FRAVEBQRFTUUNhUQFTUVNRU1FRAVEBURFBAVNRQRFRAVERM2FTUVNRU1FREUNRU1FQAFbwABKkgVAA0FAAAAAAAAAAA='
     command_off: 'JgBQAAABKpIVEBUQFBEVEBUQFBEVEBU1FRAVEBQRFTUUNhUQFTUVNRU1FRAVEBURFBAVNRQRFRAVERM2FTUVNRU1FREUNRU1FQAFbwABKkgVAA0FAAAAAAAAAAA='
   xbox_back:
     friendly_name: "XBOX BACK"
     command_on: 'JgBQAAABK5MVEBUQFRAVEBYQFRAVEBU1FRAVEBYQFTUVNRUQFTUWNBY1FTUVEBUQFRAWNBYQFRAVEBUQFTUWNRU1FRAVNRU1FQAFggABKkoVAA0FAAAAAAAAAAA='
     command_off: 'JgBQAAABK5MVEBUQFRAVEBYQFRAVEBU1FRAVEBYQFTUVNRUQFTUWNBY1FTUVEBUQFRAWNBYQFRAVEBUQFTUWNRU1FRAVNRU1FQAFggABKkoVAA0FAAAAAAAAAAA='
   xbox_hdmi:
     friendly_name: "XBOX HDMI"
     command_on: 'JgBQAAABK5EVEBURFBAVEBURFBAVEBU1FRAVERQQFTYUNRURFDUVNRURFDUVNhQQFREUNRURFBEUNhQRFBAVNhQ1FREUNRU1FQAFcQABKkcVAA0FAAAAAAAAAAA='
     command_off: 'JgBQAAABK5EVEBURFBAVEBURFBAVEBU1FRAVERQQFTYUNRURFDUVNRURFDUVNhQQFREUNRURFBEUNhQRFBAVNhQ1FREUNRU1FQAFcQABKkcVAA0FAAAAAAAAAAA='
   xbox_menu:
     friendly_name: "XBOX MENU"
     command_on: 'JgBQAAABKZIVEBUQFRAVEBUQFRAVEBU1FRAVEBUQFTUVNRUQFTUVNRU1FTUVNRU1FRAVNRU1FRAVEBURFBAVEBU1FRAVERQ1FQAFbgABKkgVAA0FAAAAAAAAAAA='
     command_off: 'JgBQAAABKZIVEBUQFRAVEBUQFRAVEBU1FRAVEBUQFTUVNRUQFTUVNRU1FTUVNRU1FRAVNRU1FRAVEBURFBAVEBU1FRAVERQ1FQAFbgABKkgVAA0FAAAAAAAAAAA='
   xbox_info:
     friendly_name: "XBOX INFO"
     command_on: 'JgBQAAABK5EWEBQQFg8WEBQQFg8WEBQ1FhAUEBYPFjQWNBUQFjUUNRYQFDUWNBY1FBAWNRQ1FhAUNRYQFBAWDxY0Fg8WDxU1FgAFbwABK0cWAA0FAAAAAAAAAAA='
     command_off: 'JgBQAAABK5EWEBQQFg8WEBQQFg8WEBQ1FhAUEBYPFjQWNBUQFjUUNRYQFDUWNBY1FBAWNRQ1FhAUNRYQFBAWDxY0Fg8WDxU1FgAFbwABK0cWAA0FAAAAAAAAAAA='
   xbox_play:
     friendly_name: "XBOX PLAY"
     command_on: 'JgBQAAABKpIVEBUQFRETERUQFRETERU1FBEVEBUREzYVNRUQFTUVNRQRFRAVEBUQFTUVNRU1FRAVNRU1FTUVNRUQFREUEBU1FQAFagABKkgVAA0FAAAAAAAAAAA='
     command_off: 'JgBQAAABKpIVEBUQFRETERUQFRETERU1FBEVEBUREzYVNRUQFTUVNRQRFRAVEBUQFTUVNRU1FRAVNRU1FTUVNRUQFREUEBU1FQAFagABKkgVAA0FAAAAAAAAAAA='
   xbox_backwards:
     friendly_name: "XBOX FAST BACKWARD"
     command_on: 'JgBQAAABKpIVDxURFBEVDxURFBEVDxU2FQ8VEBURFDUVNRUQFTUVNhQ1FREUNRURFDUVERQRFBAVERQ1FREUNRURFDUVNhQ2FAAFbgABKkgUAA0FAAAAAAAAAAA='
     command_off: 'JgBQAAABKpIVDxURFBEVDxURFBEVDxU2FQ8VEBURFDUVNRUQFTUVNhQ1FREUNRURFDUVERQRFBAVERQ1FREUNRURFDUVNhQ2FAAFbgABKkgUAA0FAAAAAAAAAAA='
   xbox_forward:
     friendly_name: "XBOX FAST FORWARD"
     command_on: 'JgBQAAABK5EVEBUQFREUEBUQFREUEBU2FBAVEBURFDUVNRUQFTUVNhQQFRAVNRUQFTUVEBURFBAVNhQ1FREUNRURFDUVNRU2FAAFbwABK0gUAA0FAAAAAAAAAAA='
     command_off: 'JgBQAAABK5EVEBUQFREUEBUQFREUEBU2FBAVEBURFDUVNRUQFTUVNhQQFRAVNRUQFTUVEBURFBAVNhQ1FREUNRURFDUVNRU2FAAFbwABK0gUAA0FAAAAAAAAAAA='
   xbox_stop:
     friendly_name: "XBOX STOP"
     command_on: 'JgBQAAABKpIUERUQFBAVERQRFBAVERQ1FREUERQQFTYUNhQRFDYUNRU2FBAVERQ1FTYVDxURFBEVDxU2FTUUERUPFTYVNRQ1FQAFbgABK0gUAA0FAAAAAAAAAAA='
     command_off: 'JgBQAAABKpIUERUQFBAVERQRFBAVERQ1FREUERQQFTYUNhQRFDYUNRU2FBAVERQ1FTYVDxURFBEVDxU2FTUUERUPFTYVNRQ1FQAFbgABK0gUAA0FAAAAAAAAAAA='
   xbox_next:
     friendly_name: "XBOX FAST NEXT"
     command_on: 'JgBYAAABKZUTEhQRExITEhMTExIUERQ2ExITEhQSEzcUNhQRFDQVNxQSEzcUERM3EzcUERQSExITNxQRFDYTExMSFDYUNhM3EwAFhAABKUsUAAxSAAEqShQADQU='
     command_off: 'JgBYAAABKZUTEhQRExITEhMTExIUERQ2ExITEhQSEzcUNhQRFDQVNxQSEzcUERM3EzcUERQSExITNxQRFDYTExMSFDYUNhM3EwAFhAABKUsUAAxSAAEqShQADQU='
   xbox_backback:
     friendly_name: "XBOX FAST BACK"
     command_on: 'JgBQAAABKZMVEBUREhIVEBUREhITEhU1FRAVEBUQEzcVNRUQFTUVNRM3FTUVEBU1FTUVEBUQFREUEBUQFTUWDxURFDUWNBY1FAAFcAABK0cVAA0FAAAAAAAAAAA='
     command_off: 'JgBQAAABKZMVEBUREhIVEBUREhITEhU1FRAVEBUQEzcVNRUQFTUVNRM3FTUVEBU1FTUVEBUQFREUEBUQFTUWDxURFDUWNBY1FAAFcAABK0cVAA0FAAAAAAAAAAA='`Preformatted text`
I finally figured out how to get the XBox One controlled by the Broadlink RM Mini and ultimately with Alexa.
This video from Paul Hibbert was a huge help: https://youtu.be/4OnUUoOYbTY
Basically, I used someone else’s cloud remote to learn the code in RM Bridge. In the Broadlink e-Control app, search for Xbox then select the ‘Microsoft’ one (the video explains this around 6min). If you just want to control the xbox via Broadlink with the app, you can stop there. If you want to activate it with voice through IFTTT, though, then you need to learn the code in RM Bridge by sending it to the RM Mini while the RM bridge is in learning mode. I couldn’t find this anywhere else online so I hope it helps.
The actual codes I got for powering off and on respectively were as follows (I named them xboxoff and xboxon):
xboxoff: 2600500000012590131210150f1611140f161213121411361411131114111336153414111138123713361411141013361015103911141214111313351534131213361015103913361000058c0001214b10000d050000000000000000
xboxon:
26005000000123901312141110160f16111412151014113614101510131210391039111412371336131213361410133610151436160f1312103910151237121313351411133610391000058d0001214b12000d050000000000000000
I figured out an easy way to program the Broadlink RM Pro with the Xbox One command to turn off. I bought an Inteset INT-422-3 which comes with full programming for the Xbox to control via IR. This includes a button to power off the Xbox One with one push instead of going through the prompts. Once you program the remote I have linked below, use the IR signal and program your Broadlink.
Inteset INT-422 4-in-1 Universal Backlit IR Learning Remote for Apple TV, Xbox One, Roku & Media Center https://www.amazon.com/dp/B00M4I1BAY/ref=cm_sw_r_cp_api_GZ61AbMNYDGWM
This… Just this is amazing
where do I write this code? I’m sorry I’m new to this and I always added devices by the IR learning process
where do you add the codes?
If using the codes provided by @domi, add them under the switch component in your configuration file.
I’m sorry I’m to noob, is the configuration file in any specific path a my android phone? or is in a desktop app?
Apologies if this seems redundant, but can you confirm that you’re using Home Assistant (eg. installed on a raspberry pi)? Or are you using the Broadlink RM as a standalone device/as-is out of the box?
Whilst this particular thread relates to the Broadlink RM, it’s in relation to the usage of that device through Home Assistant.
More information about Home Assistant is available here.
If you’re not using Home Assistant, the information in these forums probably isn’t going to be of any use.
My mistake, I am using the broadlink rm3 mini, thank you for explaining to me, I didn’t know that there was a raspberry solution, sorry and thank you anyway.
this works! awesome!
works great!
