but I noticed the scan_interval options wasn’t on the integration documentation, and it states I need a list, so, though my previous config worked until recently, Ive changed it to what’s prescribed.
No joy however, the log keeps asking me for a fresh login. which of course I have just done before restart.
2020-04-20 14:35:50 ERROR (SyncWorker_19) [homeassistant.components.xbox_live.sensor] Can't setup XboxAPI connection. Check your account or api key on xboxapi.com. Code: 401 Description: A fresh login is required to gain a new token from Microsoft
since this is a Microsoft notice, Ive even re-loggedin on the MS account for this XBOX and user.
Anyone else seeing this, and maybe have a solution?
there’s no real alternative is there?
btw since this is no CC but core, shouldn’t it be maintained somehow, to at least a functional state… couldn’t find a bug report on Github, so hoped fellow members here would know what I was doing wrong.
Integrations are maintained by the code owner. If the code owner is MIA the issue will get assigned to someone at some point.
I dropped it because of this issue but also because I never used it. Pretty much a waste of time for me. I bought a roku and that implementation works 100% better and doesn’t have a api cost.
I should have clarified. Everything I wanted to track in xbox is available in the roku. I.E. I only used my xbox account to track netflix, amazon-prime, hbo, etc. Never used it to track anything else, so it’s probably not the same as your situtation.
Cool, I’ve had a quick look in the core integrations but xbox_live/sensor.py doesn’t have this, and imports xboxapi from xbox_api…
so, not an easy PR to do for me I am afraid.
