Dear,
I saw a pull request on the core, and its closed:
Xiaomi Air Purifier 3C support is added by abrilevskiy · Pull Request #1 · abrilevskiy/core (github.com)
But I did not see the Purifier 3C in my Xiaomi Miio app
Dear,
What does the Xiaomi app has to do with Home Assistant?
Sry for misleading you, I meant the xiaomi-miio integration
Yes of course. But as you can see in the list, the " zhimi.airpurifier.mb4" is not listed.
Describe what you have tried, any messages when you add it? Anything in the log?
I added the “Xiaomi Miio” integration. Then I added the IP and the token of the Purifier.
But the device is not found. And its not in the list…
Same here. Is there someone that already have airpurifiermb4 in their home assistant?
Anyone? Is it possible to add the 3C to Home Assistant or do I have to buy the 3H?
It is supported since the end of august.
I am experiencing lots of communication failures both with official HA xiaomi-miot component and with the custom component.
Is someone else using it?
Hi, I am looking into buying this model/version (3C), is it currently working reliably in HA?
Grateful for any feedback!
Hi there, Xiaomi Mi Air Purifier 3C is supported by Xiaomi Miio integration
You only need to follow up instructions and chose zhimi.airpurifier.mb4 device, then select cloud location using list and login with your Xiaomi credentials.
