I’m looking a solution for: Unable to add Xiaomi Mi Air purifier 3H to home assistant with CN hub.
A time ago I have bought the Chinese Xiaomi Mija Gatway V3 (lumi.gateway.v3). I was only able to add it to the server from mainland china in the app and not on a EU server. Also it was possible to get the token and add the hub to Home assistant.
I only use it for the Alarm, Hub light and light sensor.
Most other xiaomi/etc. products i have use zigbee and are directly added to a ConBee II Zigbee USB dongle.
Now i have bought a Xiaomi Air Puriefier 3H, But i can not seem to add it on the Chinese server.
I am able to add it to a EU server, but then i have a major problem. On the EU server i do not have a hub, so i can not get a token.
And thereby i am unable to add Air Purifier 3H to home assistant it seems! Is this true?
What i tried so far:
- Remove the hub from the CN server and kept trying to add to a EU server. Didn’t work.
- Tried to add the 3H Air Purifier to the CN server where my hub was (re)configured. Didn’t work.
- When ait puriefier was connected to the EU server and hub to the CN server i tried adding the Air purifier manually to home assistant with the token from the CN server. Didn’t work.
Do you guys have a solution/trick/hack how this can be solved? As i want to have the air purifier 3H be controlled by other sensors i currently have. Thanks in advance.
