This blueprint will let you configure a Aqara Wireless Remote Switch (Double Rocker) (Eu Version) which is paired with Xiaomi gateway via xiaomi_aqara integration. It supports commands for single, double and long-press for each rocker or both rockers together.
Requirements:
- Aqara Wireless Remote Switch (Double Rocker). Both right and left binary_sensor entiries must have “Right” and “Left” in their names for this blueprint to work - this is a limitation of xiaomi_aqara integration.
This blueprint is based on ZHA - Aqara Wireless Remote Switch (Double Rocker) from NachtaktiverHalbaffe. Thanks!
Blueprint:
blueprint:
name: xiaomi_aqara - Aqara Wireless Remote Switch (Double Rocker)
description: Automate your Xiaomi Aqara Wireless Remote Switch (Double Rocker) using xiaomi events.
domain: automation
input:
aqara_double_switch:
name: Select the Aqara Wireless Remote Switch (Double Rocker)
description: Aqara Wireless Remote Switch (Double Rocker)
selector:
device:
entity:
integration: xiaomi_aqara
filter:
model: remote.b286acn01
button_single_press_left:
name: Single Press Left
description: Action to run on single press
default: []
selector:
button_double_press_left:
name: Double Press Left
description: Action to run on double press
default: []
selector:
button_long_press_left:
name: Long Press Left
description: Action to run when button is long pressed (held down)
default: []
selector:
button_single_press_right:
name: Single Press Right
default: []
selector:
button_double_press_right:
name: Double Press Right
default: []
selector:
button_long_press_right:
name: Long Press Right
default: []
selector:
button_single_press_both:
name: Single Press Both Buttons
description: Action to run on single presses
default: []
selector:
button_double_press_both:
name: Double Press Both Buttons
description: Action to run on double presses
default: []
selector:
button_long_press_both:
name: Long Press Both Buttons
description: Action to run when buttons are long pressed (held down)
default: []
selector:
mode: restart
max_exceeded: silent
variables:
aqara_double_switch: !input aqara_double_switch
triggers:
- trigger: event
event_type: xiaomi_aqara.click
conditions:
- condition: template
value_template: "{{ device_id(trigger.event.data.entity_id) == aqara_double_switch }}"
alias: Check for device_id
actions:
- variables:
click_type: "{{ trigger.event.data.click_type }}"
entity_id: "{{ trigger.event.data.entity_id }}"
- choose:
- conditions:
- "{{ click_type == 'single' }}"
- "{{ state_attr(entity_id, 'friendly_name') | contains('Left') }}"
sequence: !input button_single_press_left
- conditions:
- "{{ click_type == 'double' }}"
sequence: !input button_double_press_left
- conditions:
- "{{ click_type == 'long' }}"
sequence: !input button_long_press_left
- conditions:
- "{{ state_attr(entity_id, 'friendly_name') | contains('Right') }}"
sequence: !input button_single_press_right
- conditions:
sequence: !input button_double_press_right
- conditions:
sequence: !input button_long_press_right
- conditions:
- "{{ click_type == 'both' }}"
sequence: !input button_single_press_both
- conditions:
- "{{ click_type == 'double_both' }}"
sequence: !input button_double_press_both
- conditions:
- "{{ click_type == 'long_both' }}"
sequence: !input button_long_press_both
