So it has been a while since the Xiaomi Aqara Single and Double key Zigbee switches came out, one of the easiest and hassle free switches that require no neutral cable.
I have thwe D1 2 gang wireless version. Using ZHA but there seems to be no quirks for it yet. Not sure when it can be supported. May have to go Z2M route but would rather stay with ZHA
I got myself a 3-button D1 switch and then - because I did not look carefully enough - some 2-button H1 switches. They seemed to work out of the box with limited functionality. I very much wanted to use them in decoupled mode, thogh (the buttons now do not automatically toggle the switches), so I started digging into it and have a solution that works for me now. I can test the 3-button and 2-button switches but would appreciate if other models could be tested. Also it would be great if somebody had a single button D1/H1 and could send me the zigbee device description.
Aqara D1 3 gang with neutral is working fine with ZHA in home assistant . I’m using sonoff zigbee dongle . As 3 gang works fine it means all other switches from Aqara should work work this setup
Yes, they should work in their basic functions. I was missing configuration options, though. For example setting them to decoupled mode, controlling the LEDs, start-up on/off and so on. Also, I did not have device automation triggers. All this now is (should be) working with the quirk.
