Good to know that you’ve found solution. I’ve tried something else, and… success
I’ve made a copy of configuration.yaml, automation.yaml, secrets.yaml, and then I’ve made a clean install of hassio.
Then I’ve copied the files to clean installation, and to my surprise everything started working just fine.
I think that something has done some damage to the database or something (I don’t know hassio so well), and it was well hidden.
I decided to not install many add-on’s - I have a feeling that everything started working bad after DuckDNS addon installation, but that’s just a feeling.
I’ve also got debug logs turned on for this component: Found here
I run HA on a rpi2 with docker. It’s behind a traefik reverse proxy. I’ve also got my wifi network setup in WAN bypass. My wifi is done by a Archer C2 router, the rpi has a static IP. I understand that in the documentation it says that Multicast must be enabled, I imagine the issues this component has is related to that, but the question I have is:
Why does this component work following a restart, and then at some later stage, complete stop working until I restart HASS again?
Some sort of multicast timeout. The MI App and xioami gateway are on the same wifi gateway so always work . when HA loses contact with gateway is it a random time when it disconnects ?
I have 10 Xiaomi devices and all was well until I upgrade HA to version 0.82.0. Now some devices get unavailable (it seems at random times), but then after a while they get available again!!!
When was the last time the PyXiaomiGateway lib was updated in HA? Anyone know? There was at least one fix done in September of this year that might help folks
I’m having a similar issue as the others on HA 0.82.0b3. I’m having such errors:
Cannot connect to Gateway
No data in response from hub None
This started to happen since 0.82 version. Token is correct - double checked. Additionally, some more Xiaomi devices started to disconnect like power strips or Air purifier 2. It works again when it’s powered off and on.
Find out what channel your 2.4g wifi is using.
Then find the zigbee channel your gateway is using
Then look here to see if they are over lapping
try and move your 2.4g wifi channel as far away as possible from the zigbee channel as described in the above article… i did this and rarely get unavailable sensors etc
I had this issue and tried everything! The thing that solved it was a replacement router.
I found this after bringing my hass pi3, Xiaomi Gateway and a motion sensor to work, set them up in the morning on the work WiFi and seeing no dropouts after the whole day.
I was using an ISP supplied ZTE ZXHN H298N, which it turns out was either ignoring or filtering out the multicast heartbeat messages coming from the Xiaomi Gateway.
Got a TP-Link AC1750 Archer C7 and it all started working out of the box. No dropouts since (been 4 weeks now).
So, try taking a bare bones setup to another network to see how it performs. Worth a try!
That’s very weird, I have never seen that happening before then I moved it to a new network (wlan0-1 on OpenWRT) and I was having issues with invalid key which I got fixed by having a multicast proxy installed .I though that was the reason I was getting it to show Unavailable but woke up this morning to see the gateway in that state and the multicast packets are still getting received by HA so not sure what’s going on.
