Xiaomi Aqara Door and Window Sensor update interval problem
Hey everyone,
I have a problem with the update interval of my Aqara Door and Window Sensor.
Because of my ZHWG11LM Hub i had to use the homekit integration mentiened by @Olivier974
https://community.home-assistant.io/t/not-able-to-get-xiaomi-gateway-key/61795/117
So I added it via discovery -> homekit accessory -> Aqara hub. everything works fine.
BUT:
The 2 Door and Window Sensors are not updating the state properly.
A manual set scan_interval AND the service homeassistant.update_entity are not working.
The state update runs every 60 seconds.
I need an update interval somewhere between 2 and 5 seconds.
Can anyone help please?
Best regards
i dont think it s possible to choose the scan interval.
But normally, the states are update before 60s, my states are report about 10 secondes maximum…
I think you have something that interfer in your hassio installation and slow down the system…
Hope someone can help you, or do a fresh install if nobody can help :wink:
i already did a fresh install. Just have the hub and the 2 sensors running right now…
i think, there is a default value that can not be overwritten, but i can’t find it…
it worked for me for one time, but after adding another component it stopped working. After a fresh installation with the same values it doesn’t work anymore… Strange…
the value is
binary_sensor.door_and_window_sensor_76fa:
scan_interval: 3
Hope anybody can help
