I got my Xiaomi Aqara double buttons (wireless switch) yesterday and got a bit annoyed at the fact that it didn’t support double clicks and long clicks. I still haven’t been able to solve long clicks, any input is appreciated, but I did manage go implement both single and double clicks. The same could be extended to support triple clicks etc by just adding a “for: seconds: 1” to the double click automation.
# livingroom_switch_left_status:
# name: Living room switch left status
# initial: 'off'
# options:
# - 'off'
# - 'single'
# - 'double'
# - 'long'
# livingroom_switch_left_number:
# initial: 0
# min: 0
# max: 110
# step: 1
## These automations are used to set the status of an aqara button to either off, single, double or long.
## The Aqara buttons does not support this out of the box, so this is a way to emulate it with automations and input selects.
## A bit of a hack, but should work. Have to be repeated for left button, right button and both buttons in order to get it all to work.
## Then the input select can be used for automations rather than using the on/off directly. Since the Aqara buttons only show up
## as a binary sensor, it can only have two values, on or off.
# Set an input select when button is clicked.
- alias: Livingroom switch left button single click
- platform: event
event_type: click
event_data:
entity_id: binary_sensor.wall_switch_left_158d000171d630
click_type: single
condition:
- condition: state
entity_id: input_select.livingroom_switch_left_status
state: 'off'
- service: input_select.select_option
option: 'single'
# Now to detect double clicks. We detect a single click and check if the input select is already single. if so, it's a double.
- alias: Livingroom switch left button double click
- platform: event
event_type: click
event_data:
click_type: single
condition:
- condition: state
state: 'single'
option: 'double'
# If the input select doesn't change state for 2 seconds, change back to off.
- alias: Livingroom switch left button set to off
- platform: state
to: 'single'
for:
seconds: 2
- platform: state
to: 'double'
for:
seconds: 2
option: 'off'
# If the input select is double, turn off the ceiling group if on, turn on if off. Also set status to off.
- alias: Livingroom switch left button double click ceiling is on
- platform: state
to: 'double'
condition:
- condition: state
entity_id: light.living_room_roof_1
state: 'on'
- service: homeassistant.turn_off
entity_id:
- group.livingroom_ceiling
option: 'off'
- alias: Livingroom switch left button double click ceiling is off
- platform: state
to: 'double'
condition:
- condition: state
state: 'off'
- service: homeassistant.turn_on
entity_id:
option: 'off'
# I want to increase the light if single press is done. Max is 100. Starting at 5 and going up 17 per time, we get these numbers:
# 5, 22, 39, 56, 73, 90, 107
# 5 is pretty perfect for low light like watching tv, and 90 is too bright already.
# 110 is the maximum number for the input_number so I needed something that maxed out over 100 but below 110.
# Also sets the status to off so it can be used again without waiting for the reset timer
- alias: Livingroom switch left button single press increase number
- platform: state
to: 'single'
for:
seconds: 1
- service: input_number.set_value
data_template:
entity_id: input_number.livingroom_switch_left_number
value: '{{ states.input_number.livingroom_switch_left_number.state | int + 17 }}'
option: 'off'
# If we go over 100, reduce to 5 to restart the flow.
- alias: Set livingroom switch state to 5 if over 100
- platform: numeric_state
# value_template: '{{ states.input_number.livingroom_switch_left_number.state }}'
above: 100
data_template:
value: '5'
# When we change the input_number, set the ceiling group to that brightness as a percentage
- alias: Set livingroom ceiling based on input_number
- platform: state
data_template:
entity_id: group.livingroom_ceiling
brightness_pct: '{{ states.input_number.livingroom_switch_left_number.state | int }}'
# Never found a good way to make this work
#- alias: Livingroom switch left button long click
# trigger:
# - platform: event
# event_type: click
# event_data:
# entity_id: binary_sensor.wall_switch_left_158d000171d630
# click_type: single
# for:
# seconds: 1
# action:
# - service: input_select.select_option
# data:
# entity_id: input_select.livingroom_switch_left_status
# option: 'long'
Now I just have to repeat this tiny little snippet for the right button and both buttons pressed… It works pretty flawlessly, I will probably tweak the timings a bit to make it feel more intuitive. The tradeoff is I need it to be in single click status long enough for even the kids to have time to do a double click before the single click automation is triggered.
Code is also available at https://github.com/DevvAndreas/Home-Assistant-Config/blob/master/automation/state%20based/switch_automations.yaml along with the rest of my config
