I have had the Xiaomi Aqara gateway working with a handful of motion sensors for a while now and jsut recently it has been failing to load whenever I restart Home Assistant. The logs always say something like this:
2019-03-18 19:20:08 ERROR (SyncWorker_3) [homeassistant.components.xiaomi_aqara] No gateway discovered
2019-03-18 19:20:08 ERROR (MainThread) [homeassistant.setup] Setup failed for xiaomi_aqara: Component failed to initialize.
I am able to get it to load if I unplug the gateway and then restart Home Assistant. It is as if the gateway is only discoverable a few minutes after being restarted. Any help would be greatly appreciated.
