I had configured the Xiaomi Aqara Hub long time ago and the token was stored into the configuration.xml. However, I cannot seem to find that configuration in the file anymore. Furthermore, I cannot seem to retrieve the token key from the iOS app anymore as well. So while the integration is still working I cannot figure out what the token key is anywhere. Where exactly does Home Assistant store the value?
config > .storage > core.config_entries
Thank you much!
