I did but using Z2M (although I had the issue with both Z2M and ZHA). In the end, with Z2M it was just a matter of re-pairing continuously until it worked. I suspect it would be the same on ZHA but I haven’t tried.
I put the device right next to the hub and it interviewed immediately.
Same issue here, it pairs and immediately leaves. No idea how to get it connected properly.
Device 0xxxxx (54:ef:xx:xx:xx:xx:xx:xx) left the network
I have no problem pairing an Aqara motion sensor, but the problem is that it won’t detect any motion.
Hello Dean. I suffered same problem and also resetting hundred times but I finally link to zigbee network.
Answer was simple. Replace the battery.
Darn I’m so upset Aqara didn’t mentioned this.
Anyway. Forks, replace the battery. That’s all.
Thank you so much!!
It is exactly how you describe. Click very shortly again and again.
I kept on clicking 30 times ore more than it worked for me.
