- Raspbian on Ras Pi 1B
- Home assistant on Rasbian (v.0.69.1)
- Disabled firewall on router, no firewall in Raspbian
- Enabled Lan access
- Tried to leave the MAC address mac: blank
My config :
xiaomi_aqara:
discovery_retry: 10
gateways:
- mac: 7811dcb7bb6d
key: 2ypq9y75v4pgj48f
Im newbie. I’m trying to setup xiaomi aqara. When i start Home assistant i got error. It is worth mentioning that I previously installed xiaomi gateway success. But when i restart Pi, i got this problem.
May 18 01:48:26 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform xiaomi_aqara
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 129, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for
return fut.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/xiaomi_aqara.py", line 24, in setup_platform
for (_, gateway) in hass.data[PY_XIAOMI_GATEWAY].gateways.items():
KeyError: 'xiaomi_gw'
return fut.result()
And log :
May 18 01:48:58 raspberrypi hass[3376]: 2018-05-18 01:48:58 INFO (Thread-3) [homeassistant.components.xiaomi_aqara] Discovering Xiaomi Gateways (Try 10)
May 18 01:49:03 raspberrypi hass[3376]: 2018-05-18 01:49:03 INFO (Thread-3) [xiaomi_gateway] Gateway discovery finished in 5 seconds
May 18 01:49:03 raspberrypi hass[3376]: 2018-05-18 01:49:03 ERROR (Thread-3) [homeassistant.components.xiaomi_aqara] No gateway discovered
May 18 01:49:03 raspberrypi hass[3376]: 2018-05-18 01:49:03 INFO (MainThread) [homeassistant.setup] Setup of domain xiaomi_aqara took 52.2 seconds.
May 18 01:49:03 raspberrypi hass[3376]: 2018-05-18 01:49:03 ERROR (MainThread) [homeassistant.setup] Setup failed for xiaomi_aqara: Component failed to initialize.
May 18 01:49:03 raspberrypi hass[3376]: 2018-05-18 01:49:03 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_call_id=3049867408-4, domain=persistent_notification, service_data=notification_id=invalid_config, title=Invalid config, message=The following components and platforms could not be set up:
May 18 01:49:03 raspberrypi hass[3376]: - [xiaomi-aqara](https://home-assistant.io/components/xiaomi_aqara/)
May 18 01:49:03 raspberrypi hass[3376]: Please check your config., service=create>
May 18 01:49:03 raspberrypi hass[3376]: 2018-05-18 01:49:03 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=persistent_notification.invalid_config, old_state=None, new_state=<state persistent_notification.invalid_config=notifying; title=Invalid config, message=The following components and platforms could not be set up:
May 18 01:49:03 raspberrypi hass[3376]: Please check your config. @ 2018-05-18T08:49:03.351548+07:00>>
And log :
May 18 01:49:23 raspberrypi hass[3376]: 2018-05-18 01:49:23 INFO (MainThread) [homeassistant.components.discovery] Found new service: xiaomi_gw {'host': '192.168.1.102', 'mac_address': '7811dcb7bb6d', 'hostname': 'lumi-gateway-v3_miio78811079.local.', 'port': 54321, 'properties': {'epoch': '1', 'mac': '7811dcb7bb6d'}}
May 18 01:49:23 raspberrypi hass[3376]: 2018-05-18 01:49:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event platform_discovered[L]: discovered=host=192.168.1.102, mac_address=7811dcb7bb6d, hostname=lumi-gateway-v3_miio78811079.local., port=54321, properties=epoch=1, mac=7811dcb7bb6d, service=xiaomi_gw>
Thank so much!
. Thanks everyone!
