Hi all
I have a problem integrating 2 “Xiaomi Aquara temperature sensors”.
I installed ZIGBEE2MQTT and CC2531 dongle. I already have Shellys who work well with MQTT on my Hass.io.
I made all the configurations, paired the 2 Xiaomi sensors, I find the 2 devices in the \ share \ zigbee2mqtt \ devices file, there are the sensor states in the \ share \ zigbee2mqtt \ state.json file.
The problem is that I don’t find the 2 sensors in the list of entities !!! I think of a problem in the MQTT platform scripts, but I don’t know where to look for it.
Has anyone had the problem before?
I. have this script in \config\packages\zigbee2mqtt.yaml like info about integration:
# Input select for Zigbee2mqtt debug level
input_select:
zigbee2mqtt_log_level:
name: Zigbee2mqtt Log Level
options:
- debug
- info
- warn
- error
initial: info
icon: mdi:format-list-bulleted
# Input text to input Zigbee2mqtt friendly_name for scripts
input_text:
zigbee2mqtt_old_name:
name: Zigbee2mqtt Old Name
zigbee2mqtt_new_name:
name: Zigbee2mqtt New Name
zigbee2mqtt_remove:
# Scripts for renaming & removing devices
script:
zigbee2mqtt_rename:
alias: Zigbee2mqtt Rename
sequence:
service: mqtt.publish
data_template:
topic: zigbee2mqtt/bridge/config/rename
payload_template: >-
"old": "{{ states.input_text.zigbee2mqtt_old_name.state | string }}",
"new": "{{ states.input_text.zigbee2mqtt_new_name.state | string }}"
zigbee2mqtt_remove:
alias: Zigbee2mqtt Remove
sequence:
data_template:
topic: zigbee2mqtt/bridge/config/remove
payload_template: "{{ states.input_text.zigbee2mqtt_remove.state | string }}"
# Timer for joining time remaining (120 sec = 2 min)
timer:
zigbee_permit_join:
name: Time remaining
duration: 120
# Sensor for monitoring the bridge state
- platform: mqtt
name: Zigbee2mqtt Bridge state
state_topic: "zigbee2mqtt/bridge/state"
icon: mdi:router-wireless
# Sensor for Showing the Zigbee2mqtt Version
- platform: mqtt
state_topic: "zigbee2mqtt/bridge/config"
value_template: "{{ value_json.version }}"
icon: mdi:zigbee
# Sensor for Showing the Coordinator Version
- platform: mqtt
value_template: "{{ value_json.coordinator }}"
icon: mdi:chip
# Switch for enabling joining
switch:
- platform: mqtt
name: "Zigbee2mqtt Main join"
state_topic: "zigbee2mqtt/bridge/config/permit_join"
command_topic: "zigbee2mqtt/bridge/config/permit_join"
payload_on: "true"
payload_off: "false"
automation:
# Automation for sending MQTT message on input select change
- alias: Zigbee2mqtt Log Level
initial_state: "on"
platform: state
entity_id: input_select.zigbee2mqtt_log_level
- service: mqtt.publish
payload_template: "{{ states('input_select.zigbee2mqtt_log_level') }}"
topic: zigbee2mqtt/bridge/config/log_level
# Automation to start timer when enable join is turned on
- id: zigbee_join_enabled
alias: Zigbee Join Enabled
hide_entity: true
platform: state
entity_id: switch.zigbee2mqtt_main_join
to: "on"
service: timer.start
entity_id: timer.zigbee_permit_join
# Automation to stop timer when switch turned off and turn off switch when timer finished
- id: zigbee_join_disabled
alias: Zigbee Join Disabled
hide_entity: true
- platform: event
event_type: timer.finished
event_data:
- platform: state
to: "off"
- service: timer.cancel
- service: switch.turn_off
