Hi all,
I have a problem with my aqara wireless relay controller https://www.aliexpress.com/i/32982164582.html
It is connected to gateway and I am able to control it throuth mihome app just as 8 other devices that is connected to it.
Problem is that I see and can control those 8 other devices through homeassistant exept this one.
Tryed reading it to gateway multiple times no lukc. Added couple new devices like power plug, showed in homeassistant right away.
Coud it be that this device is not supported?
Edit:
And I hahe this in my log:
ERROR (SyncWorker_2) [xiaomi_gateway] The device with sid 158d0005733dbd isn't supported of the used gateway firmware. Please update the gateway firmware if possible! This is the only way the issue can be solved.
