Hi, I have recently added an ESP32 bluetooth proxy to be able to connect BLE devices to my HA, but I encountered a problem with my Xiaomi Mi Body Composition Scale 2.
It is successfully discovered and I have an option to set it up with Xiaomi_BLE, but after I add it, it seems to not have an entity for the impedance sensor, only the weight.
I want to use the Bodymiscale integration, but without the impedance, it’s a bit a waste of potential.
Does anyone have an idea what can be the cause of such behavior, I would be really grateful!
Please note that you have to stay on the scale until the display has switched itself to off. Otherwise some data like i.e. the impedance might not have been send to HA in time.
You were right, I really didn’t think that I need to stand longer to measure the impedance and for the entity to appear in HA. Now that looks just like on your screenshots.
Thankyou!
Hi, i tried to add my Mi Body Composition Scale 2 (XMTZC05HM) via the Xiaomi BLE integration and got the same problem, that only “Mass Non Stabilized” got detected.
I’m using a Raspberry Pi 4 and the integrated bluetooth antenna/hardware.
Tried removing all integrations from HA and resetting the scale (taking out the batteries for over 1 hour), but no change.
