Have these
can we have it showing their Device name not their “Found name”
eg the 58-2D-34-35-90-39 has a Device name of BT SpareRoom
and the 1st “MJ_HT_V1” has a device name “Lounge BT”
Simply use the three dot menu in the integration page to rename them.
True Good Point but
wouldn’t the logic be going into the Device its self then working out the Name Logic which would feed back to the Integration Screen?
otherwise I will be naming it twice??
That is only the case if there is exactly one device per integration. Afaik what you’re seeing is not multpile devices, but multiple instances of the same integration. And each instance can have 0 or more devices. So in your case it may seem logical as each integration holds one device, but for the generic structure of integrations it is not.
Here’s an exapmple for multiple Spotify integrations that do not have devices, only services/entities:
