Xiaomi BLE Occupancy Sensor XMOSB01XS
Hello everyone, please tell me how to fix this? My sensor only shows Illuminance
Where is occupancy ?
From this: https://smarthomescene.com/reviews/xiaomi-battery-ble-occupancy-sensor-review/
Additionally, if you successfully integrate the device but only see the signal strength or illuminance sensors available, it likely indicates a voltage drop in the battery, meaning it needs to be replaced. Save yourself the frustration—just replace the battery!
Thanks, I will try. But battery shows as 100% :thinking:
I removed the battery and check voltage, there was 3V (full charge) then I inserted it and a miracle happened
It seems that rebooting the sensor helped
Hi
I am thinking about buying this sensor. How do you find it so far, would you recommend it?
Also how is the battery holding up?
I just got a couple and they’re a bit of a pain to get working with all the messing about with a Xiaomi account but, once that’s done they work great so far.
I can’t say how the battery will hold up yet though.
