Xiaomi BLE Temperature and Humidity sensor with mini pc - Hassio on VM
Hi Guys,
i’m currently running hassio on RP3+ and i planning to migrate to old mini PC on VM (virtualbox) that i have (i5 8giga ram).
my only question is there a way to retrieve data from Bluetooth devices like in a rp3?
i have 3 of Xiaomi BLE Temperature and Humidity sensor in my house and it be a waste not to be able to use them.
i tried same configuration but it wont poll any data.
i have both on board Bluetooth and external
any idea?
usb, non of them working.
log file:
2019-04-15 18:18:13 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
2019-04-15 18:18:13 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform bluetooth_tracker
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/device_tracker/ init .py”, line 184, in async_setup_platform
disc_info)
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/bluetooth_tracker/device_tracker.py”, line 81, in setup_scanner
for dev in discover_devices():
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/bluetooth_tracker/device_tracker.py”, line 59, in discover_devices
lookup_class=False, device_id=device_id)
File “/usr/local/lib/python3.7/site-packages/bluetooth/bluez.py”, line 26, in discover_devices
device_id = _bt.hci_get_route()
OSError: [Errno 97] Address family not supported by protocol
2019-04-15 18:18:44 WARNING (SyncWorker_1) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:18:44 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:18:45 WARNING (SyncWorker_4) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:18:45 WARNING (SyncWorker_1) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:18:45 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:18:45 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:19:15 WARNING (SyncWorker_4) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:19:15 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:19:15 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:19:15 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:19:15 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:19:46 WARNING (SyncWorker_1) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:19:46 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:19:46 WARNING (SyncWorker_4) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:19:46 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:19:46 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:19:46 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:20:17 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:20:17 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:20:17 WARNING (SyncWorker_4) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:20:17 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:20:48 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:20:48 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:20:48 WARNING (SyncWorker_4) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:20:48 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:20:48 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:20:48 WARNING (SyncWorker_1) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:21:18 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:21:18 WARNING (SyncWorker_1) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:21:18 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:21:18 WARNING (SyncWorker_4) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:21:18 WARNING (SyncWorker_1) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:21:49 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:21:49 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:21:49 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:21:49 WARNING (SyncWorker_1) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:21:49 WARNING (SyncWorker_4) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:21:49 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:22:20 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:22:20 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:22:20 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:22:20 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:22:50 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:22:50 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:22:50 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:22:50 WARNING (SyncWorker_4) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:22:50 WARNING (SyncWorker_1) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:23:21 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:23:21 WARNING (SyncWorker_1) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:23:21 WARNING (SyncWorker_4) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:23:21 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:23:21 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:23:52 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:23:52 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:23:52 WARNING (SyncWorker_1) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:23:53 WARNING (SyncWorker_4) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:23:53 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:23:53 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:24:23 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:24:23 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:24:23 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:24:23 WARNING (SyncWorker_1) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:24:53 WARNING (SyncWorker_4) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:24:53 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:24:53 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:24:53 WARNING (SyncWorker_1) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:24:53 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:24:53 WARNING (SyncWorker_4) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:25:24 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:25:24 WARNING (SyncWorker_1) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:25:24 WARNING (SyncWorker_4) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:25:24 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:25:24 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:25:24 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:25:55 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:25:55 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:25:55 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:25:55 WARNING (SyncWorker_4) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:25:55 WARNING (SyncWorker_1) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:26:26 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:26:26 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:26:26 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:26:26 WARNING (SyncWorker_1) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:26:26 WARNING (SyncWorker_4) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:26:57 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:26:57 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:26:57 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:26:57 WARNING (SyncWorker_1) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:26:57 WARNING (SyncWorker_4) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:27:27 WARNING (SyncWorker_3) [homeassistant.components.mitemp_bt.sensor] Polling error
2019-04-15 18:27:27 WARNING (SyncWorker_2) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
2019-04-15 18:27:27 WARNING (SyncWorker_0) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:27:27 WARNING (SyncWorker_4) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D1:EE:4B
2019-04-15 18:27:27 WARNING (SyncWorker_1) [homeassistant.components.mitemp_bt.sensor] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D5:9F:77
any idea?
does your mini pc have bluetooth?
Yes, I have Bluetooth on the mini pc.
Do I need to configure something in virtual box ?
Help someone?
