Try to put sensors really close to rpi. I think it could be poor antennas problem (out of range).
same problem for me⦠not working even at 2cm from pi
Hi!
I beginer with Home assistant.
I have two BLE sensor.
Mi Plants Flower monitor and Xiaomi BLE Temperature and Humidity sensor.
I use Homeassistant with Synology (Intel) with Docker.
Both BLE sensor works well if I add only one.
But If I add both BLE sensors, home assistant recongizes datas (temperature, humidity and battery ) only second one (Xiaomi LCD sensor in my sample) in configuration.yaml.
My sample code:
Xiaomi Mi plant sensor
-platform: miflora
mac: C4:7C:8D:67:3B:XX
force_update: false
median: 3
monitored_conditions:
-moisture
-light
-temperature
-conductivity
-battery
Xiaomi LCD sensor living room
- platform: mitemp_bt
mac: 4C:65:A8:X8:AD:A1
name: Kids Room Temp
force_update: false
median: 3
-temperature
-humidity
-battery
Ha you got any idea?
Have you tried moving it closer?
the rpi really does have rubbish BT range (i have issues past 4m)
these are the steps i took to get it right:
1 - press button on back of sensor to make it ādiscoverableā
2 - told my cellphone to find bluetooth devices (you have 30 seconds)
3 - see what cellphone found and it should give the mac of the device, will be listed as MJ_HT_V1
4 - used the following config
- platform: mitemp_bt mac: '4c:65:a8:xx:xx:xx' name: Lounge force_update: false median: 1 monitored_conditions: - temperature - humidity - battery
5 - restarted HA
in your overview you should see 3 new badges with hyphens in them
the data will be populated a few minutes later with the next poll (default is 5 mins)
I have done the same as you have outlined. I have my temp sensor sitting next to my pi. Is there some way of knowing if the piās bluetooth is activated? Do I have to install the mitemp_bt component? Iām using Hassio.
Ironically I had the same issue a few weeks ago after I was messing around.
I searched the internet high and low and this was the basic result I got - reinstall, it either works on install or not.
Backed up config (not a snapshot)
reinstall hassio with latest image
put config back
hey presto - BT was working again.
So thats my answer - sorry mate, reinstall hassio
Sorry for the hijack, but what is the update frequency like on the bluetooth temperature sensor? Iām using a xiaomi zigbee temperature sensor, but that only updates once an hour, or after a 0.5deg temperature change (whichever happens first).
looking for more frequent updates.
I just tried this, still not working. Even with the sensor sitting next to the Pi. Anyway of knowing if the Piās bluetooth is activated or working? Should the Piās bluetooth be discoverable using a BLE app?
Pi3 and latest hassio should have it on by default, I donāt know of a way to test
You can set the frequency to a point using a median of updates
Median set to 1 polls data every 5 minās.
Median 3 will take the average of 3 scans (15mins) and sends that - median is useful to prevent spikes.
You can also set force update to true which sends new values regardless of if they have changed or not.
@Eatoff try the commands mentions here to see if it returns values
I have a strange problem that sensor stops working after several days (around 3-5). After the restart of Pi is works again. Any ideas how to solve it?
P.S. even the restart of Hassio doesnāt help only the restart of Pi
I donāt have any xiaomi BLE sensors, but I have a Bluetooth kettle working with a custom component, and it behaves the same way, loses connection after 3-5 days and needs a full pi reboot. So I believe the problem is in the Bluetooth part of hass.io in general.
How do you restart Pi?
I would like to test this, I have two and experience the same issue.
Can restarting Pi be automated?
Did you solve this issue ? I also have this problem. Full restart of PI or from hassio ssh login and systemctl restart bluetooth.
I never resolved it, I bought the square temp and humidity sensor and they work like a charm.
Hi everyone,
Wondering if anyone has had the same issue as I have. I have the MI sensor and have been able to successfully pair the device to home assistant via getting itās mac address but i canāt get any data through no matter how long i wait?
Anyone had the same issue and able to resolve it?
just to add seeing this in the logs
2019-07-14 16:45:42 WARNING (MainThread) [homeassistant.components.sensor] Updating mitemp_bt sensor took longer than the scheduled update interval 0:00:30
Could not solve the problem with BLE sensor and did exactly the same as SimonT, bought a square Zig.Bee version - Xiaomi Aqara Atmos
Hi guys,
My setup is raspbian and hassio into a docker container.
Iāve managed to connect to the xiaomi sensor using by default bluetooth from raspberry pi, but iāve got some awkward error and had to unlock the bluetooth using the command rfkill unblock bluetooth.
After iāve inserted the config lines into configuration.yaml file and starting the docker container all is good, but after 4-5 (few) hours, the sensor stop transmitting data and in the logs iāve got only these kind of events
2019-07-16 13:49:51 WARNING (SyncWorker_15) [homeassistant.components.sensor.mitemp_bt] Polling error
2019-07-16 13:49:51 WARNING (SyncWorker_4) [homeassistant.components.sensor.mitemp_bt] Polling error
If iām stopping the container and restarting it, the sensor starts behave normally (i donāt want to setup a cronjob to do this)
Does anybody have any clue why is having this behavior?
Iāll still try and troubleshoot this and hope that iāll find the root cause.
I have hass.io running in Docker on my debian server. Iām also having the issue where the it stops getting the data.
I also have normal HA running in a virtual environment on a pi and itās also having the same issue. Seems that something with Home Assistant (doesnāt matter is it normal HA or hassio) is causing the issue, or the Xiaomi BLE sensor, but like others have said, a reboot seems to fix it.
Itās kind of annoying as I brought this for the display as where I have it is in a heavy traffic area in my house, otherwise I would have got one of the square zigbee ones like I have elsewhere.
