Xiaomi BLE Temperature and Humidity sensor
anyone got this working in HASSIO? on a pi b+
cant seem to poll. I got the BLE mac via android app and added to config but no joy.
> Log Details (WARNING)
> Thu Jul 26 2018 13:35:00 GMT+1000 (Australian Eastern Standard Time)
> Polling error Could not read data from Mi Temp sensor 4c:65:a8:d3:d5:ca
I’ve the same issue. No idea what I’m doing wrong. I followed the following steps:
  1. Discovered the MAC address using my Android phone (by pairing with the BLE sensor)
  2. Added the below to my configuration
  3. The error logs show that Hassio is unable to retrieve any values from the sensor.
  4. Placed the BLE sensor within 1m of the Raspberry Pi
  5. Restarted the Raspberry Pi
I’m on Hassio 0.71 btw. Do I need to pair the sensor with the Raspberry Pi? Seems unusual that all one needs is the MAC address and voila, you can read the BLE sensor readouts.
  - platform: mitemp_bt
    mac: '4C:65:A8:D8:7F:58'
    name: Xiaomi BLE Sensor
2018-07-28 13:21:32 WARNING (SyncWorker_8) [homeassistant.components.sensor.mitemp_bt] Polling error
2018-07-28 13:21:32 WARNING (SyncWorker_17) [homeassistant.components.sensor.mitemp_bt] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D8:7F:58
2018-07-28 13:21:34 WARNING (SyncWorker_14) [homeassistant.components.sensor.mitemp_bt] Polling error Could not read data from Mi Temp sensor 4C:65:A8:D8:7F:58
using a ble app on android i can see the temp and humid reading so it must just advertise without really having to pair to it
I have had no issues apart from taking over 10 seconds sometimes.
From having a look it seems you don’t need to ā€œpairā€ it. Once the MAC address is found it should be fine.
With the code (just thinking out loud) does it work if you include the ā€˜monitored conditions’ even though it’s optional?
good idea - didn’t work sadly. are you running the latest hassio build?
Not brave enough for Hassio yet. Still on hassbian.
Hey all, mine is working now. Turns out the bluetooth range between the raspberry pi and the sensor isn’t great. I’ve to have both in the same room to get the sensor data into Hass
did you install the BLE addon? I have it working
no the new hassio blog said don’t install it it’s on by default.
do you have a link to the ble addon. i can’t find it in the hassio addon lists
Ohhh sorry I’m still on resinOS. if you’re on HassOS you need to keep it disabled
edit: grammar
I’m having the same issue… anyone found a solution yet?
I moved mine closer to my
Pi and rebooted and it’s working
Bluetooth range of the raspberry pi isn’t great
i have nearly the same issue, but i didn’t see any warning in logs.
i have no value received and no warning in log
I have the same error here.
Could it be due the fact, that those sensors are from Aliexpress (region mainland China)? I mean I cant use them in mainland Europe in Android app Mi Home, but I cant successfully use them in region mainland china.
Could be this limitation directly in the firmware of the sensors?
A spark from my log:
I used the config from here:
The topic is already discussed here. For Domoticz there is a python script, which by the comments of other looks like, that reading of the sensor can be done. Does it mean, that there is an error in Home Asistant add-on?
https://www.domoticz.com/forum/viewtopic.php?t=21904
https://www.domoticz.com/forum/viewtopic.php?f=56&t=20925
Oh man… one of ours is playing up all of a sudden. I put the sensor RIGHT NEXT to the pi but just get the ā€œPolling error Could not read data from Mi Temp sensorā€
EDIT: Turns out the program I use to find the Mac address wasn’t showing me the correct one. I had to take the batteries out of all my other devices and then it found it.
Helps when you have the right Mac address huh!
Same issues here. +some fails.
Log snip:
Update for sensor.outside_humidity fails
11:40 components/sensor/mitemp_bt.py (ERROR)
Update for sensor.outside_temperature fails
Updating mitemp_bt sensor took longer than the scheduled update interval 0:00:30
11:39 helpers/entity_platform.py (WARNING)
Update of sensor.kueche_humidity is taking over 10 seconds
11:39 util/async_.py (WARNING)
11:39 components/sensor/mitemp_bt.py (ERROR)
Update of sensor.wohnzimmer_humidity is taking over 10 seconds
Update of sensor.flur_humidity is taking over 10 seconds
11:38 components/sensor/mitemp_bt.py (ERROR)
11:38 helpers/entity_platform.py (WARNING)
My config:
  - platform: yr
#xiaomi bt temp und hygro sensoren
    mac: '4C:65:A8:REMOVED'
    monitored_conditions:
      - temperature
      - humidity
      - battery
      - temperature
      - humidity
      - battery
      - temperature
      - humidity
      - battery
      - temperature
      - humidity
      - battery
Hardware: RPi3 B+
Bluetooth: OnBoard
Network over: LAN
I try this here: Xiaomi Thermostat (with display) - Page 2 - Domoticz
myUser@raspberrypi:~ $ dpkg --status bluez | grep ā€˜^Version:’
Version: 5.43-2+rpt2+deb9u2
So, if this is still a bug, my 5.43-2 should be a ā€˜bug-version’.
Then I disable pnat plugin, by editing /etc/bluetooth/main.conf with sudo and add + reboot:
DisablePlugins=pnat
Another problem could just be the low rPi3 antenna. A solution could be to attach sma connector to it:
alt text
Source (in german)
What is the base of the HA mitemp-hygro-temp implementation? This here:
Greetings by JamieMe
Can anybody help with this issue?
Greetings by JamiueMe
