Using the instructions in : Xiaomi Mijia BLE Temperature and Humidity Sensor - Home Assistant
Setup:
Raspberry Pi 4 with SD Card Hass.io
Home Assistant Version: core-2021.4.5
Xiaomi Temp Sensor 2 Info: Firmware 1.0.0_0109; Hardware B1.4
I’ve followed the steps and added everything to my configuration.yaml file, as stated in the example for temperature, humidity and battery life. I have used the bluetoothctl method to ensure the Pi can see the devices. I cross-referenced the MAC address via the Xiaomi Home App, after setting them all up on my phone. An example of my YAML is:
sensor.Family_Bathroom_Temp:
- platform: mitemp_bt
mac: "A4:C1:38:78:D7:D0"
name: Family Bathroom Temperature & Humidity
force_update: true
median: 1
monitored_conditions:
- temperature
- humidity
- battery
## Xiaomi Token: b96911009932a0a76a14c06e
I’ve modified the sensor.XX name, the MAC address, and the Name to create unique devices. However when I reset my Pi completely, Home Assistant complains that this is invalid:
Logger: homeassistant.setup
Source: setup.py:164
First occurred: 14:27:52 (4 occurrences)
Last logged: 14:27:52
Setup failed for sensor.Living_Room_Temp: Integration not found.
Setup failed for sensor.Master_Bedroom_Temp: Integration not found.
Setup failed for sensor.Family_Bathroom_Temp: Integration not found.
Setup failed for sensor.Kitchen_Temp: Integration not found.
