Xiaomi Body Sensor - "No motion since"?
Hi there,
I’m having trouble extracting a certain attribute from a sensor.
I can see the attribute “No motion since” in teh dev-tool:
I want to use this value (300 in the example) but can’t find the proper syntax.
{{ states.binary_sensor.motion_sensor_158d00016db13b.attributes.no_motion_since }} does nothing.
I also tried {{ states.binary_sensor.motion_sensor_158d00016db13b.attributes.last_motion }} and {{ states.binary_sensor.motion_sensor_158d00016db13b.attributes.last_trigerred }} without any luck. There are also no errors in the dev-tool.
Can anyone help me out?
Have you tried {{ states.binary_sensor.motion_sensor_158d00016db13b.attributes.No_motion_since }}, with an uppercase N for “No_motion_since”?
Yes I did, same result (which is none)
Use {{states.binary_sensor.motion_sensor_158d00016db13b.attributes['No motion since']}}
@arsaboo that works, thanks for the prompt reply!
What does no motion since “300” mean? My one says that but I can interpret
300 seconds (so 5 minutes).
Thanks @Bob_NL
Does it max out at 300 seconds?
Is there anyway to do last motion 6:45pm Wednesday for example? That would be really nice to see!
If you want to display the last motion event date and time you could use this is your configuration.yaml:
  • platform: template
    sensors:
    last_motion:
    friendly_name: “Last motion date-time”
    value_template: >-
    {{(as_timestamp(now()) - states.binary_sensor.motion_sensor_xxxxxxxxxxx.attributes[‘No motion since’] | int) | timestamp_custom(’%Y-%m-%d %H:%M’)}}
This will take the current timestamp then substract the “No motion since” value from it and format the result to “2019-03-27 16:48” date&time format.
