My fix isnt’ part of 0.84(.1). You’ve to wait for 0.85. It’s not broken again. It’s still broken. Trust me the issue will be solved soon.
soon as in 9th january
Yes the next release will be on 09.01
Do you have any idea, how I can edit the file myself on hassio? Or fix it myself in any way?
Edit:
Adding the content of the xiaomi_aqara.py
file with your fix to /config/custom_components/binary_sensor/xiaomi_aqara.py
should work, right?
Edit2:
I can confirm, that now the right last_action
is displayed in the dev-state
page, but still it does not trigger any automation…
Edit3:
So I recreated all my automations and now they seem to work again
Thanks for the help!
The fix is part of 0.84.2 now!
I’ve just updated to 84.2 and my switches now work… thank you
hmm. mine now shows the clicks as registered after upgrading to 84.2, but automation still doesn’t run.
84.0 and 84.1 doesn’t even show any clicks being registered at all.
I revered to 82.1 and it is all working now…
So seems like my fix is not there yet, waiting for next year. No biggie.
Merry Christmas and Happy New Year to all !
The same situation here, issue not fixed yet in 0.84.2. In version 82.1 my Xiao mi WXKG02LM AQARA Smart switch still works fine.
In 0.84.2 the sensors below are registered and visible on the dev-stat page in the GUI, but their state remain off
no matter I push one or both buttons.
binary_sensor.wall_switch_left_158d00xxxxxxxx
binary_sensor.wall_switch_right_158d00xxxxxxxx
binary_sensor.wall_switch_both_158d00xxxxxxxx
My other Xiaomi sensors (like below) work just fine in 0.83.x and 0.84.x:
binary_sensor.motion_sensor_158d000xxxxxxxx
sensor.temperature_158d000xxxxxxxx
sensor.pressure_158d000xxxxxxxx
sensor.humidity_158d000xxxxxxxx
Edit:
Down here my xiaomi debug logging.
dec 17 07:08:44 nuc.bachstraat20 docker[12783]: 2018-12-17 07:08:44 DEBUG (SyncWorker_12) [homeassistant.components.xiaomi_aqara] Expecting 1 gateways
dec 17 07:08:44 nuc.bachstraat20 docker[12783]: 2018-12-17 07:08:44 INFO (SyncWorker_12) [homeassistant.components.xiaomi_aqara] Discovering Xiaomi Gateways (Try 1)
dec 17 07:08:50 nuc.bachstraat20 docker[12783]: 2018-12-17 07:08:50 DEBUG (SyncWorker_12) [homeassistant.components.xiaomi_aqara] Gateways discovered. Listening for broadcasts
dec 17 07:09:14 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:14 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Temperature_158d000xxxxxxx: 18.4>: {'voltage': 2975, 'temperature': '1839', 'humidity': '5412', 'pressure': '100955'}
dec 17 07:09:14 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:14 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Humidity_158d000xxxxxxx: 54.1>: {'voltage': 2975, 'temperature': '1839', 'humidity': '5412', 'pressure': '100955'}
dec 17 07:09:14 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:14 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Pressure_158d000xxxxxxx: 1009.5>: {'voltage': 2975, 'temperature': '1839', 'humidity': '5412', 'pressure': '100955'}
dec 17 07:09:21 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:21 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Plug_158d000xxxxxxx: on>: {'voltage': 3600, 'status': 'on', 'inuse': '1', 'power_consumed': '1484', 'load_power': '1.66'}
dec 17 07:09:36 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:36 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Motion Sensor_158d000xxxxxxx: off>: {'lux': '4'}
dec 17 07:09:36 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:36 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Illumination_158d000xxxxxxx: 4.0>: {'lux': '4'}
dec 17 07:09:36 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:36 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Motion Sensor_158d000xxxxxxx: off>: {'status': 'motion'}
dec 17 07:09:36 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:36 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Illumination_158d000xxxxxxx: 4.0>: {'status': 'motion'}
dec 17 07:09:41 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:41 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Humidity_158d000xxxxxxx: 52.2>: {'temperature': '2070'}
dec 17 07:09:41 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:41 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Temperature_158d000xxxxxxx: 20.5>: {'temperature': '2070'}
dec 17 07:09:41 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:41 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Pressure_158d000xxxxxxx: 1009.7>: {'temperature': '2070'}
dec 17 07:09:41 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:41 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Humidity_158d000xxxxxxx: 52.2>: {'humidity': '5149'}
dec 17 07:09:41 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:41 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Temperature_158d000xxxxxxx: 20.7>: {'humidity': '5149'}
dec 17 07:09:41 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:41 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Pressure_158d000xxxxxxx: 1009.7>: {'humidity': '5149'}
dec 17 07:09:41 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:41 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Humidity_158d000xxxxxxx: 51.5>: {'pressure': '100975'}
dec 17 07:09:41 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:41 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Temperature_158d000xxxxxxx: 20.7>: {'pressure': '100975'}
dec 17 07:09:41 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:41 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Pressure_158d000xxxxxxx: 1009.7>: {'pressure': '100975'}
dec 17 07:09:41 nuc.bachstraat20 docker[12783]: 2018-12-17 07:09:41 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Humidity_158d000xxxxxxx: 51.5>: {'voltage': 2985, 'temperature': '2070', 'humidity': '5149', 'pressure': '100975'}
dec 17 07:10:28 nuc.bachstraat20 docker[12783]: 2018-12-17 07:10:28 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Humidity_158d000xxxxxxx: 64.2>: {'voltage': 2975, 'temperature': '1796', 'humidity': '6423', 'pressure': '101025'}
dec 17 07:10:28 nuc.bachstraat20 docker[12783]: 2018-12-17 07:10:28 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Pressure_158d000xxxxxxx: 1010.2>: {'voltage': 2975, 'temperature': '1796', 'humidity': '6423', 'pressure': '101025'}
dec 17 07:10:36 nuc.bachstraat20 docker[12783]: 2018-12-17 07:10:36 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Wall Switch (Left)_158d000xxxxxxx: off>: {'channel_0': 'click'}
dec 17 07:10:36 nuc.bachstraat20 docker[12783]: 2018-12-17 07:10:36 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Wall Switch (Both)_158d000xxxxxxx: off>: {'channel_0': 'click'}
dec 17 07:10:36 nuc.bachstraat20 docker[12783]: 2018-12-17 07:10:36 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Wall Switch (Right)_158d000xxxxxxx: off>: {'channel_0': 'click'}
dec 17 07:10:43 nuc.bachstraat20 docker[12783]: 2018-12-17 07:10:43 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Wall Switch (Left)_158d000xxxxxxx: off>: {'channel_1': 'click'}
dec 17 07:10:43 nuc.bachstraat20 docker[12783]: 2018-12-17 07:10:43 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Wall Switch (Both)_158d000xxxxxxx: off>: {'channel_1': 'click'}
dec 17 07:10:43 nuc.bachstraat20 docker[12783]: 2018-12-17 07:10:43 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Wall Switch (Right)_158d000xxxxxxx: off>: {'channel_1': 'click'}
The 6th - 4th last lines appeared when I pressed the left button. The last 3 lines appeared when I pressed the right button.
I’m having the same issue.
I’ve changed the event to xiaomi_aqara.click and it worked until last update.
I’ve noticed that all xiaomi devices stopped to send events: I’ve some door/windows sensor and motion detection. I can see the state but they doesn’t fire events anymore.
Any idea?
If you just updated from 0.82 to 0.84 and automation stops working, please make sure you have updated all event type values which now require “xiaomi_aqara.” prefix
0.82
event_type: click
Now:
event_type: xiaomi_aqara.click
This worked after update to 0.83 till last version
- alias: Toggle light
platform: event
event_data:
entity_id: binary_sensor.switch_158d0002287ab4
click_type: single
service: light.toggle
entity_id: light.yeelight_rgb_34ce00818743
This one stopped to work after last update:
- alias: Alarm
- platform: state
entity_id: binary_sensor.motion_sensor_158d0001e15d46
to: 'on'
- platform: state
entity_id: binary_sensor.door_window_sensor_158d00019fec42
to: 'on'
- service: notify.telegram_message
I opened an issue:
This doesn’t work for me. Even in HA 0.84.3.
I tested my automation using an example (see below) provided by @syssi and it proved the sensor is working. The conclusion is that my action is not working any more.
- alias: Test single click event of the wall switch
platform: event
event_data:
entity_id: binary_sensor.wall_switch_left_158d00027c19e9
click_type: single
- service: persistent_notification.create
title: "Aqara Wall Switch"
message: "Single press of the left button detected"
With this example I get notifications in the UI.
Edit: My automation was disabled. After I enabled the automation it worked again.
Problem solved.
In all automation must be set:
initial_state: 'on'
Thanks a million
That worked for me! Couldn’t figure it out last night.
Example working code:
- alias: Long Click to toggle Light Strip
initial_state: 'on'
platform: event
event_data:
entity_id: binary_sensor.switch_118xxxxxxxxxxx
click_type: long_click_press
- service: light.toggle
entity_id:
- light.light_strip
I can confirm this worked for me…
J
since updating from 0.82.0 to 0.84.6 my Xiaomi buttons no longer work for the double_click and long_press_click… I updated the code to account for the breaking changes hence the single click is working. Anyone know if this is a HA fault that is yet to be fixed?
Here is an example of one package which is only working for the single click but not the other click types:
automation:
- alias: Ensuite Remote Button
initial_state: 'on'
- platform: event
event_data:
entity_id: binary_sensor.switch_158d00016bf679
click_type: single
- platform: event
event_data:
click_type: double
- platform: event
event_data:
- service: switch.turn_off
data_template:
entity_id: '{% if trigger.event.data.click_type == "single" %} switch.circadian_lighting_ensuite_circadian_lighting {% endif %}'
- service: light.turn_on
data_template:
entity_id: '{% if trigger.event.data.click_type == "single" %} light.ensuite_light {% endif %}'
brightness: 255
rgb_color: [255,255,255]
- service: automation.turn_off
data_template:
entity_id: '{% if trigger.event.data.click_type == "single" %} automation.ensuite_light_auto_on_motion {% endif %}'
data_template:
entity_id: '{% if trigger.event.data.click_type == "single" %} automation.ensuite_light_off_after_2mins {% endif %}'
- service: light.turn_off
data_template:
entity_id: '{% if trigger.event.data.click_type == "double" %} light.ensuite_light {% endif %}'
data_template:
entity_id: '{% if trigger.event.data.click_type == "double" %} automation.ensuite_light_auto_on_motion {% endif %}'
data_template:
entity_id: '{% if trigger.event.data.click_type == "double" %} automation.ensuite_light_off_after_2mins {% endif %}'
- service: switch.turn_on
data_template:
entity_id: '{% if trigger.event.data.click_type == "long_click_press" %} switch.circadian_lighting_ensuite_circadian_lighting {% endif %}'
- service: automation.turn_on
data_template:
entity_id: '{% if trigger.event.data.click_type == "long_click_press" %} automation.ensuite_light_auto_on_motion {% endif %}'
data_template:
entity_id: '{% if trigger.event.data.click_type == "long_click_press" %} automation.ensuite_light_off_after_2mins {% endif %}'
This is working for me. We have some syntax differences.
############ Mini Button ###############
- id: mini_button
alias: "Mini Button"
platform: event
event_data:
entity_id: binary_sensor.mini_button
- service_template: >
{% if trigger.event.data['click_type'] == 'long_click_press' %}
homeassistant.toggle
{% elif trigger.event.data['click_type'] == 'single', 'double' %}
homeassistant.turn_on
{% else %}
{% endif %}
data_template:
entity_id: >
{% if trigger.event.data['click_type'] == 'single' %}
script.tv_lights
{% elif trigger.event.data['click_type'] == 'double' %}
script.pause_living_room_harmony
{% elif trigger.event.data['click_type'] == 'long_click_press' %}
input_boolean.block_all_motion_lights
{% else %}
light.gateway_light2
{% endif %}
- service: input_select.select_option
data_template:
entity_id: input_select.mini_button_last_action
option: >
Single Click
Double Click
Long Press
{% else %}
Unknown
{% endif %}
Finally got around to updating my switches. Thanks for the code!!!
