Hello, my Xiaomi WXKG01LM button https://www.zigbee2mqtt.io/devices/WXKG01LM.html
suddenly started to send barrages of commands instead of single ones. It worked perfectly fine for months. This is a result of a SINGLE click:
zigbee2mqtt:info 2020-01-21 15:24:37: MQTT publish: topic 'zigbee2mqtt/0x00158d0003d4d912', payload '{"battery":100,"voltage":3042,"linkquality":44,"click":"single"}'
zigbee2mqtt:info 2020-01-21 15:24:37: MQTT publish: topic 'zigbee2mqtt/0x00158d0003d4d912', payload '{"battery":100,"voltage":3042,"linkquality":44,"click":""}'
zigbee2mqtt:info 2020-01-21 15:24:37: MQTT publish: topic 'zigbee2mqtt/0x00158d0003d4d912', payload '{"battery":100,"voltage":3042,"linkquality":42,"click":"long"}'
zigbee2mqtt:info 2020-01-21 15:24:37: MQTT publish: topic 'zigbee2mqtt/0x00158d0003d4d912', payload '{"battery":100,"voltage":3042,"linkquality":42,"click":""}'
zigbee2mqtt:info 2020-01-21 15:24:37: MQTT publish: topic 'zigbee2mqtt/0x00158d0003d4d912', payload '{"battery":100,"voltage":3042,"linkquality":47,"click":"long_release","duration":29}'
zigbee2mqtt:info 2020-01-21 15:24:37: MQTT publish: topic 'zigbee2mqtt/0x00158d0003d4d912', payload '{"battery":100,"voltage":3042,"linkquality":47,"click":""}'
zigbee2mqtt:info 2020-01-21 15:24:37: MQTT publish: topic 'zigbee2mqtt/0x00158d0003d4d912', payload '{"battery":100,"voltage":3042,"linkquality":47,"click":"long_release","duration":25}'
zigbee2mqtt:info 2020-01-21 15:24:38: MQTT publish: topic 'zigbee2mqtt/0x00158d0003d4d912', payload '{"battery":100,"voltage":3042,"linkquality":44,"click":"long"}'
zigbee2mqtt:info 2020-01-21 15:24:38: MQTT publish: topic 'zigbee2mqtt/0x00158d0003d4d912', payload '{"battery":100,"voltage":3042,"linkquality":44,"click":""}'
zigbee2mqtt:info 2020-01-21 15:24:38: MQTT publish: topic 'zigbee2mqtt/0x00158d0003d4d912', payload '{"battery":100,"voltage":3042,"linkquality":44,"click":"long_release","duration":78}'
zigbee2mqtt:info 2020-01-21 15:24:38: MQTT publish: topic 'zigbee2mqtt/0x00158d0003d4d912', payload '{"battery":100,"voltage":3042,"linkquality":47,"click":"long_release","duration":128}'
zigbee2mqtt:info 2020-01-21 15:24:38: MQTT publish: topic 'zigbee2mqtt/0x00158d0003d4d912', payload '{"battery":100,"voltage":3042,"linkquality":47,"click":""}'
zigbee2mqtt:info 2020-01-21 15:24:38: MQTT publish: topic 'zigbee2mqtt/0x00158d0003d4d912', payload '{"battery":100,"voltage":3042,"linkquality":44,"click":"long_release","duration":278}'
Why does it do that and how do I fix this? Fully updated zigbee2mqtt component and Hassio 0.104.2. It is NOT a result of upgrading, it worked flawlessly for two days. Thanks!
