Xiaomi cloud authentication problem
I used the xiaomi clout to use my lumi.gateway.mieu01 only as a led light. Since 3 days i cannot authenticate my xiaomi account in the home assistant integration.
Does someone has the same problem?
Yes I have the same issue. I would like to reassign my Roborock S5 max but it is always telling me " Could not login to Xiaomi Miio Cloud, check the credentials." . But I am able to login with my credentials to the Xiaomi Cloud directly with my credentials
And this only since 2-3 i think i’ll delete my actual Xiaomi account and to create a new one…
Update: i added correctly the xiaomi account to home assistant. But after thar i recieve this message:
DeviceException during setup of xiaomi gateway with host {self._host}
Can anybody help me?
I am unable to authenticate in the integration. I know the password is correct as it gets me into the app.
could solve my login problem by changing my password. My first password was classified by xiaomi mi as to weak. After changing it to a stronger password I did not get any issue and use my devices within Home Assistant again.
Maybe a password change can help.
Mine is a google generated strong password, so I doubt that’s the issue. Although I guess it’s worth a shot.
I have the same issue. I changed password and nothing happend. Maybe first generation gateway is not supported.
Still getting this error mesaage and I cant see device and sensors in list:
Xiaomi Miio
Retrying setup: DeviceException during setup of xiaomi gateway with host {self._host}
Hi
I do have the same exact problem. DeviceException during setup of xiaomi gateway with host {self._host}
My 3 lumi.gateway.mieu01 are unavailable since november. I used a old backup with an older version of home assistant and it worked for two of them. After an update none worked.
Edit: same problem for a lumi.gateway.mgl03-Linux (some sub entities are working but not all)
Since yesterday’s update 1 of my gatewway get back to work. But the 3 others still don’t work.
Is there some update about this issue? My other Xiaomi cloud entities works well but gateway still get this error:
Also have this issues. Anyone with an idea how to fix? :slight_smile:
Update:
I disabled the “Two Step Confirmation” on my account. That fixed it for me.
Update2:
No it stopped working again :frowning:
The issue still exists. The reason is that XIaomi changed their login API.
The issue has been discussed here : Log in to the Xiaomi Miio cloud failed with correct credentials ¡ Issue #58991 ¡ home-assistant/core ¡ GitHub
And here (library used by the integration) : login failed with "Unknown exception occurred!" ¡ Issue #6 ¡ Squachen/micloud ¡ GitHub
The issue still hasn’t been solved on the library used, so the Xiaomi Home integration won’t work. Until someone fixes it.
Starting to look into Home Assistant and I also have this issue. Unfortunately, the github issue is closed due to staleness. Anyone else still encountering this?
Use PiotrMachowski/Xiaomi-cloud-tokens-extractor: This tool/script retrieves tokens for all devices connected to Xiaomi cloud and encryption keys for BLE devices. (github.com)
It should fail because of 2 factor authentication, in my case, following the link brings me to the page to link an email address. I can skip it, but that won’t solve the problem. To stop the 2 factor authentication, you have to link your email. After linking, the token extractor will succeed, as well as the HA integration.
Basically, either log in to xiaomi account from Mijia app and follow the email link process, or use the token extractor to generate the link to link email, and then you should be able to login without the 2 factor auth problem.
I enthusiastically followed the process you kindly posted for getting round the TFA
I followed the link on the exe to the Xiaomi site which required a validation of the email address
This came back with an empty page with just the word ‘ok’
Running the exe again and I still get blocked by
‘Two factor authentication required, please use following url and restart extractor:’
All very sad
Any suggestions on where I might be going wrong or what I can try?
The process did work after several attempts.
I think there might be some latency after linking the email on the Xaomi cloud account
Anyway after approx 30 mins I ran the exe yet again. Magic! This time the login worked - a list of devices and binding keys where previously I had been blocked with a TPA request
No matter how many times I try or how long I leave between attempts, I’m always denied by the need for two factor authentication. Can anyone suggest anything?
Thanks in advance.
any one find how?!
this worked for me (no 2FA active, but still had issues)
You can add them manually by going to the integrations page and adding the integration there. The config flow has a checkbox “configure manually” which lets you input the IP address and the token.
