ok, do you mean the Raspi on which HA is running or the Mac from which I access the HA UI via the browser?
On Raspberry
Hi, finally I success to install the integration by manual install pybase64 package. Here is what I did for anyone got same problem.
- ssh to system (in my case Ubuntu 18.04)
- run command:
docker exec -it homeassistant /bin/bash
- then Install pybase64
pip install --no-use-pep517 pybase64
- Restart HA
By the way, my vacuum model is Gen1 (SDJQR01RR). Thanks
I am glad you got it working Unfortunately it’s possible that you will have to do it after every HA update
If you use extractor with a map card you can update to the latest version to enable automatic map calibration
How does that work actually?
It uses image and calibration generated by extractor
I can’t login at all. I have tried every country, without country, with userID and email. Nothing seems to work.
Any ideas what I could have done wrongly?
Logger: homeassistant.helpers.entity
Source: custom_components/xiaomi_cloud_map_extractor/xiaomi_cloud_connector.py:65
First occurred: 9:07:50 PM (7 occurrences)
Last logged: 9:08:19 PM
Update for camera.xiaomi_cloud_map_extractor fails
File "/home/pi/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 278, in async_update_ha_state
await self.async_device_update()
File "/home/pi/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 471, in async_device_update
await self.hass.async_add_executor_job(self.update) # type: ignore
File "/usr/lib/python3.7/concurrent/futures/thread.py", line 57, in run
File "/home/pi/.homeassistant/custom_components/xiaomi_cloud_map_extractor/camera.py", line 175, in update
self._logged = self._connector.login()
File "/home/pi/.homeassistant/custom_components/xiaomi_cloud_map_extractor/xiaomi_cloud_connector.py", line 88, in login
return self.login_step_1() and self.login_step_2() and self.login_step_3()
File "/home/pi/.homeassistant/custom_components/xiaomi_cloud_map_extractor/xiaomi_cloud_connector.py", line 65, in login_step_2
self._ssecurity = json_resp["ssecurity"]
KeyError: 'ssecurity'
You can try using this tool, it will be easier to find correct credentials and by using it you will be able to test them without HA restart.
I will give it a try, thanks!
I’ve found the server and was able to login on the tool you linked. But I am still getting the same error on the component. Do I need to set the login/password between ’ ’ or ‘’ ‘’?
Either of them should work. If you have any of them in password then you should use the other one.
I’ve tried many combinations with/without ’ ’ or " ", but it doesn’t work in any way. I do have symbols on my password, maybe it is glitching something somehow?
You can try to get the same value by e.g. yaml GUI editor or calling a persistent_notification.create
service. If you will get a correct value then it should work in camera’s config.
Could you please elaborate on this subject? I didn’t quite understand what you meant by “calling a persistent_notification.create
service”. Thanks again
@Kabala
black one:
colors:
color_map_inside: [50, 50, 50]
color_map_outside: [0, 0, 0, 128]
color_map_wall: [255,255,255]
blue one uses a default config.
@Bhgp-git
Using dev tools (developer-tools/service
) you can try calling persistent_notification.create
service with data:
title: "Test"
message: "ThisIsMy'Password\"12$3!!!"
Which attribute should I call?
My idea is to send a notification that will contain a password to check if it is provided correctly
The notification as you posted displays correctly without the " ".
