Xiaomi Cloud Vacuum Map Extractor
Cant seem to be able to get this camera to work in homekit. Anyone have luck with this?
Any idea, i recent purchase S5 Max, but my surprise is not possible install Valetudo.
My question is. ( i integrate the S5 Max in HA all correct), bur is possible integrate maps??
How too
Anyway, I can sometimes get good results cleaning zone by zone, max 2 zones. Just too bad that Xiaomi people stopped firmware development for this model… This card will increase life of my cleaner!
It should work (supported devices). Everything you need to know is in documentation, I strongly suggest using HACS and recommended configuration
i have Roborock S5 Max. Last Version of Hassio in Docker on Rpi-4
Installed intergration with HACS. Restarted.
Added config
</s> <s>camera:</s> <s> - platform: xiaomi_cloud_map_extractor</s> <s> host: 192.168.178.76</s> <s> token: XXXXXXXXXXXXXXXXXXX</s> <s> username: XXXXXXXXXXXXX</s> <s> password: XXXXXXXXXX</s> <s> draw: ['all']</s> <s> attributes:</s> <s> - calibration_points</s> <s>
But it do not pass config check
waited lot of minutes.
Without config above - check takes 4 sec.
What could it be?
Thanks a lot!
This helped Xiaomi Cloud Vacuum Map Extractor
The same happens to me, and finally…I restart HA without passing check configuration and, for me, it works. Be sure to have a snapshot just in case.
Also interested in the dreame f9, this is the same as the xiaomi mi essential, right? Does it support no-go zones? I need that… I have heard it was experimental, and now removed…
i am going to buy a second cleaner for upstaris, i was thinking for the Dreame F9 , is it supported?
this custom component works for HA integration: https://github.com/microfrost1/xiaomi_vacuum
but will the map extractor work?
I don’t think so…
Can you make it supported? :slight_smile:
It’s not so simple :wink:
ok, my dreame f9 xiaomi arrived, i can maybe help to make this integration possible?
its also now on my same xiaomi account as my roborock s5
i did try your integration, but got time outs offcourse? can i help?
I am not planning to focus on it right now, maybe someday :slight_smile:
Ok, np , let me know :slight_smile:
Is there a chance to implement 2 different cards from 2 Roborocks?
What i have to change?
Can i set a unique id each?
gtx
Hi, can you add support for Vacuum Mop 1C?
@mochito You have to provide a name in config
@Dragonerix It’s not so simple, please check out this issue
Yes, but name doesn’t change the id I*ve tried with a different name but it only changed the displayed name.
@3_14, just a question, you are aware of the problems with map representation using gen1, as you can read the map in the xiaomi cloud, I was wondering if it was possible to write, replace the map?
As a workaround now I use a script to start a standard clean for 30 seconds and go back to docking in order to reset the map when it becomes too dirty (unexpected rotations). Sure you have a clever solution!
Unfortunately it’s not possible to upload a map :frowning: the only solution I know is to use zones cleaning instead of normal one to avoid map rotation
