I use google assistant, i have just created template switch with a zone service that I expose to google, the same works for apple⌠You just need to expose your switches, or you can expose also scrips to make it easier
2020-12-29 14:19:12 ERROR (SyncWorker_14) [miio.miioprotocol] Got error when receiving: timed out
2020-12-29 14:19:12 WARNING (SyncWorker_14) [custom_components.xiaomi_cloud_map_extractor.camera] Got exception while fetching the state: No response from the device
2020-12-29 14:19:16 WARNING (MainThread) [homeassistant.components.camera] Updating xiaomi_cloud_map_extractor camera took longer than the scheduled update interval 0:00:05
2020-12-29 14:19:21 WARNING (MainThread) [homeassistant.components.camera] Updating xiaomi_cloud_map_extractor camera took longer than the scheduled update interval 0:00:05
2020-12-29 14:19:26 WARNING (MainThread) [homeassistant.components.camera] Updating xiaomi_cloud_map_extractor camera took longer than the scheduled update interval 0:00:05
2020-12-29 14:19:31 WARNING (MainThread) [homeassistant.components.camera] Updating xiaomi_cloud_map_extractor camera took longer than the scheduled update interval 0:00:05
Question⌠(as a completly noob in HA)
I got this working (big thanks to the author), but I feel that the âmapâ have a bad resolution.
Itâs blurry and not as nice as the maps shown here.
What can I make to improve the image (map) quality?
Itâs possible that your browser doesnât support type of extrapolation used in a card (it should work in Chrome). You can add a scale: 2 in configuration of extractor
Installation of python-secrets took a very long time and have two prerequisite libxml2-dev libxslt-dev.
After that everithing has gone right. Thank for this very good integration
yes, it took a very long time to install python-secrets. And without it Hassio reports an error when adding the âcameraâ configuration to configuration.yaml
Maybe this should be added to the guide:
(assuming Raspberry Pi with python virtual environment)
install dependencies:
sudo apt-get install libxml2-dev libxslt-dev
then activate the virtual environment and install python-secrets
pip3.8 install python-secrets
(probably would work with pip3 but I had a custom python3.8 built from sources and installed on my Pi and did not want to experiment)
I have the âThe websocket command âcamera_thumbnailâ has been deprecatedâ error but no map update! Only after a reboot starts updating, then stops again after a while
I got the extractor working on hassio, but is there an way to actually extract the rrmap file so I can read the file with roboMapViewer to get the coordinate.
