Xiaomi Cloud Vacuum Map Extractor
Try to add these lines to your configuration.yaml (after calibration_points)
scan_interval:
  seconds: 30
auto_update: true
It worked for me.
Unfortunately, that did not work.
Thanks!
How can I chance the installation type?
If I install a new VM and restore HA?
The vacuum is Roborock S5 Max
:thinking::thinking:
@CommittotheIndian Do you have anything in logs? Eg just after HA start
@Mabaelst You would have to ditch HassOS, I donā€™t think itā€™s worth itā€¦
Initially after restart all I get is the warning it took longer than 10 seconds.
Logger: homeassistant.helpers.entity
Source: helpers/entity.py:476
First occurred: March 30, 2021, 7:05:05 PM (48 occurrences)
Last logged: 3:42:37 AM
Update of camera.xiaomi_cloud_map_extractor is taking over 10 seconds
Update of vacuum.webette is taking over 10 seconds
After a few hours I got a couple of these:
Logger: custom_components.xiaomi_cloud_map_extractor.camera
Source: custom_components/xiaomi_cloud_map_extractor/camera.py:194
Integration: xiaomi_cloud_map_extractor (documentation)
First occurred: 3:40:39 AM (1 occurrences)
Last logged: 3:40:39 AM
Got exception while fetching the state: Unable to discover the device 10.10.*.*
Logger: homeassistant.components.camera
Source: helpers/entity_platform.py:605
Integration: Camera (documentation, issues)
First occurred: 3:40:57 AM (1 occurrences)
Last logged: 3:40:57 AM
Updating xiaomi_cloud_map_extractor camera took longer than the scheduled update interval 0:00:30
Which is weird because again I can control it, see sensor, etc. That last one just started after adding the scan_interval part to my config mentioned a couple posts up.
I am using the Xiaomi Mio integration instead of the YAML for control ever since I moved my HA Instance to a blue. I could still control it with YAML before though.
Thank you!
If I understand correctly, if I start a new VM and I re-integrate the Vacuum Cleaners should this work?
This is a new installation. I could add text to the previous one. What have I done differently now than last time?
Suppose I reinstall everything, do I need to install another package from HA?
Thank you for your response.
@CommittotheIndian please check if token token is still valid. You can do it using tokens extractor
@Mabaelst the problem is that (as far as I know) HassOS doesnā€™t have any preinstalled font. I will try make it possible to provide your own font file
OK thank you.
But then I donā€™t understand that I could use text (freesans.ttf) in a previous installation of HA and not with this new installation!
I can not get any of the token extractor apps to work. Iā€™m still trying to figure out another way.
Could I still control the vacuum if the token had changed?
@Mabaelst what type of installation was it?
@CommittotheIndian probably notā€¦ Maybe IP address is invalid? You can check current configuration of integration in .storage directory
Pulled my token, itā€™s the same. The file from my phone with the token also showed the correct IP.
@CommittotheIndian maybe something blocks traffic to Xiaomi cloud? (adguard/pihole/ā€¦)
@Mabaelst previous one, not current :wink:
Sorry, but I donā€™t remember that correctly.
I think I did exactly the same with this new installation as with the previous one and then I was able to add text. Thatā€™s why I wonder why it doesnā€™t work with this new one?
:rofl: :innocent:
Okay so I saw that earlier you said that the token has to be in single or double quotes. Does this go for the other login info as well?
camera:
  - platform: xiaomi_cloud_map_extractor
    name: xiaomi_vacuum_map < no quotes here?
    host: "192.168.1.2"
    token: "1a2b3c4d5e6g7h7i8j"
    username: "johndoe"
    password: "password"
    draw: ['all']
    attributes:
      - calibration_points
I have the same issue as @CommittotheIndian and I actually do run pihole.
After a quick look at your code, I identified three domains for whitelisting:
Letā€™s see if that helps. Did I forget anything?
@kongo09 & @3_14
Unfortunately doesnā€™t look like that works either. I added those sites to my whitelist and disabled pihole for good measure. Still sits idle.
This is the only error Iā€™m getting right now.
First occurred: 8:06:08 PM (1 occurrences)
Last logged: 8:06:08 PM
Not sure if others will pop up later.
@Mabaelst I have no ideaā€¦
@combative-american you can use quotes in every text parameter
@kongo09 @CommittotheIndian vacuum also has to have access to Xiaomi servers + probably it has to be in the same subnet as HA
Subnet is the same. I wouldnā€™t know why there wouldnā€™t be any access to Xiaomi servers. If I remember correctly, I didnā€™t have any errors before 2021.3 version of HA. Actually, at the same time, I also started to get a lot of errors concerning cast devices.
Are you aware of any changes in the inner workings of HA that could be at the root here?
Same as @kongo09,
My subnet is the same. My HA can ping and control the vacuum so it is clearly communicating with it. Iā€™m on 2021.3.4. After a few hours of running, checked the logs again and now Iā€™m showing these errors.
Logger: homeassistant.components.xiaomi_miio.vacuum
Source: components/xiaomi_miio/vacuum.py:506
Integration: Xiaomi Miio (documentation, issues)
First occurred: 3:40:29 AM (2 occurrences)
Last logged: 10:16:31 AM
First occurred: 3:40:41 AM (1 occurrences)
Last logged: 3:40:41 AM
