Nice finding! I will add it in documentation
I m trying to make this work in the Xiaomi Vacuum Map Card. Here is the code.
- type: 'custom:xiaomi-vacuum-map-card'
entity: vacuum.xiaomi_vacuum_cleaner
map_camera: camera.xiaomi_roborock_map
calibration_points:
- vacuum:
x: 25500
'y': 25500
map:
x: 539
'y': 285
- vacuum:
x: 26500
'y': 26500
map:
x: 584
'y': 241
- vacuum:
x: 25500
'y': 26500
map:
x: 539
'y': 241
Note: not sure why there is ’ ’ on the Y. Added automatically by HA.
The problem is when I command the vacuum cleaner to go to 1 point, it does the opposite. See below :
I have just published an update for extractor that calculates calibration_points
for Lovelace Xiaomi Vacuum Map card. You can follow a progress of integration here.
cool, this would be nice!
Right now you have to manually copy these values from attributes, but finally they will be taken from camera automatically
Hello
A stackable Vacuum-Mop P STYTJ02YM
Is your component not working?
It has navigation system and LDS (laser navigation sensor)
It should work if it’s natively supported by HA
It might work, you have to check it by yourself
checked, does not work. Maybe because I have Mi home by vevs installed
Still have the same problem. Why there is ‘Y’ added by HA?
calibration_points:
- vacuum:
x: 25500
'y': 25500
map:
x: 469
'y': 318
- vacuum:
x: 26500
'y': 26500
map:
x: 496
'y': 293
- vacuum:
x: 25500
'y': 26500
map:
x: 469
'y': 293
This is just a formatting, it doesn’t affect anything. Is calibration correct?
I followed the calibration guide. The question i had is should use the map b4 or after trim? Also the the reference point (0,0) for Paint is on top left corner. Is this correct? Also why HA added ’ ’ for Y axis
Is there any hope to get support for Valetudo firmware?
When you use calibration from attributes of a camera you don’t have to adjust anything , provided that you don’t modify image. If you want to do it, do it in a camera using trim
Doesn’t valetudo already have a way to extract a map?
how to find out which xiaomi server you are connected to?
One of: ru
, us
, tw
, sg
, cn
, de
and can it be that my server is not in the list?
I think it’s the connection you use in xiaomi app, I have europe, so I choose .de
Actually I’m trying to add this camera in your vacuum map card but couldn’t get it to work. There is something wrong with the calibration points. It seems to be rotated 180 deg.
It’s literally in the README:
calibration_points
- Calculated calibration points for Lovelace Xiaomi Vacuum Map card. WARNING: this attribute doesn’t support map rotation.
Just remove rotate: 180
from your config
