Very good project that i hope will solve the problem of the coordinates for my s5max.
I try it with the map card and everythings goes well apart a “little” detail: the home-assistant_v2.db rises rapidly from 400 mb to 2 tb. I have the vacuum in the recorder because i need to know when the vacuum start (because of an automation).
I am pretty sure that the growth of the DB is due to the integration. I deleted the DB twice and every time it rises again over 2 tb, once i eliminated this integration and deleted again the DB it stops to grown.
You just have to use calibration_points
and correct calibration will appear in attributes (documentation)
Thanks heaps for this…Massive thumbs up for you sir
Thanks again, I really like this custom component. A coffee is on the way
I wanted to ask once if there is an easy way to get the room numbers? So that I can set them correctly under “room_colors”.
I want to set the same colors as in the Xiaomi app.
App:
Lovelace:
Many thanks again
I have seen that it usually starts at 16, you can check with this service:
- data:
entity_id: vacuum.roborock_s5_max
command: app_segment_clean
params:
- 16
service: vacuum.send_command
you can use the service to send the vacuum cleaner to a room. If while you see the app my home you can see how the corresponding room is marked. If no room is marked, the number not correspond to any, and with a bit of try and failure you will get all numbers.
Great integration.
I test it with my STYJ02YM but it doesn’t work, maybe you can have a look at the error:
Update for camera.xiaomi_cloud_map_extractor fails
File "/usr/local/lib/python3.8/site-packages/miio/miioprotocol.py", line 177, in send
"send (timeout %s): %s",
socket.timeout: timed out
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 278, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 471, in async_device_update
await self.hass.async_add_executor_job(self.update) # type: ignore
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/config/custom_components/xiaomi_cloud_map_extractor/camera.py", line 144, in update
map_name = self._vacuum.map()[0]
File "/usr/local/lib/python3.8/site-packages/miio/vacuum.py", line 222, in map
def log_upload_status(self):
File "/usr/local/lib/python3.8/site-packages/miio/device.py", line 124, in send
def send(
File "/usr/local/lib/python3.8/site-packages/miio/miioprotocol.py", line 215, in send
try:
try:
try:
File "/usr/local/lib/python3.8/site-packages/miio/miioprotocol.py", line 218, in send
return payload
miio.exceptions.DeviceException: No response from the device
Thank you!
I will try to add support for your vacuum, but I will need some help, as I don’t have it
Yes no problem, feel free to ask
hmm, updated to 116.0 , is it possible that the lovelace card is broken? i cant draw zones anymore ?
edit: wrong topic i will post in the lovelace topic
But it’s annoying to check all the room in that way. Doesn’t it? You can use the ‘miio’ library to check the room’s IDs
Hello @sermayoral. Exactly! I also find it cumbersome to find out the room number this way.
What exactly do you mean by ‘miio’ Libary and how do I have to use it to get the room numbers?
Thanks in advance
I think I will be able to add a list of room numbers as a attribute…
That would be awesome!
You can get the room ID by using:
miio protocol call <roboip> get_room_mapping
I added calibration_points
command but i can’t find the coordinates
Can you show your config?
#mappa robot
camera:
- platform: xiaomi_cloud_map_extractor
host: !secret walle_ip
token: !secret walle_token
username: !secret mi_user
password: !secret mi_pwd
country: "de"
colors:
color_map_inside: [32, 115, 185]
color_map_outside: [19, 87, 148]
color_map_wall: [100, 196, 254]
color_map_wall_v2: [93, 109, 126]
color_grey_wall: [93, 109, 126]
color_path: [147, 194, 238]
color_goto_path: [0, 255, 0]
color_predicted_path: [255, 255, 0, 0]
color_zones: [0xAD, 0xD8, 0xFF, 0x8F]
color_zones_outline: [0xAD, 0xD8, 0xFF]
color_virtual_walls: [255, 0, 0]
color_no_go_zones: [255, 33, 55, 127]
color_no_go_zones_outline: [255, 0, 0]
color_no_mop_zones: [163, 130, 211, 127]
color_no_mop_zones_outline: [163, 130, 211]
color_charger: [0x66, 0xfe, 0xda, 0x7f]
color_robo: [75, 235, 149]
color_unknown: [0, 0, 0]
color_scan: [0xDF, 0xDF, 0xDF]
room_colors:
1: [240, 178, 122]
2: [133, 193, 233]
3: [217, 136, 128]
4: [52, 152, 219]
5: [205, 97, 85]
6: [243, 156, 18]
7: [88, 214, 141]
8: [245, 176, 65]
9: [252, 212, 81]
10: [72, 201, 176]
11: [84, 153, 199]
12: [133, 193, 233]
13: [245, 176, 65]
14: [82, 190, 128]
15: [72, 201, 176]
16: [165, 105, 18]
draw:
- charger
- path
- goto_path
- predicted_path
- no_go_zones
- no_mopping_zones
- vacuum_position
- virtual_walls
- zones
attributes:
- charger
- goto
- goto_path
- goto_predicted_path
- image
- no_go_areas
- no_mopping_areas
- obstacles
- path
- vacuum_position
- walls
- zones
- calibration_points
Config seems to be correct, calibration points should be available in camera’s attributes.
New feature:
I have added returning room numbers in a dedicated attribute: room_numbers
